gotscottgreen
#1 Posted : Friday, July 31, 2020 1:13:53 AM(UTC)
gotscottgreen
Hey All,
So I am looking to record multiple streams (recording out and multicorder) to a 4:2:2 colorspace. I shot all this weekend to H.264 using 75Mbps and H264High profile and I only show a 4:2:0 colorspace. I am using BM Decklink Quad 2 and cameras that output 4:2:2, so what format do I need to record in to get 4:2:2?
I may do up to 5 cameras, I tried ProRes and it ate a LOT of CPU power for just one camera multicorder and was huge (expected), is there another format (AVI, vMix AVI, FFMPEG, or others) that I can record to that gives me 4:2:2?
I have a Quadtro RTX 4000 so I could do a lot of encoding at once, but thought H264 would do 4:2:2.
Any help is apprciated!
Thanks in advance!
Xavier
#2 Posted : Friday, July 31, 2020 1:45:27 AM(UTC)
H.264 4:2:2 is not natively supported by NVENC HW encodes but 4:4:4 is
https://developer.nvidia...m/nvidia-video-codec-sdk
You can verify this very easily :
Code:
ffmpeg -h encoder=nvenc
>>     Supported pixel formats: yuv420p nv12 p010le yuv444p p016le yuv444p16le bgr0 rgb0 cuda d3d11
For libx264
ffmpeg -h encoder=libx264
>>     Supported pixel formats: yuv420p yuvj420p yuv422p yuvj422p yuv444p yuvj444p nv12 nv16 nv21 yuv420p10le yuv422p10le yuv444p10le nv20le gray gray10le
You might want to try to add your own recording settings (for 4:4:4) for FFMPEG/NVENC in the ffmpegformats.xml file under the streaming folder of vMix installation folder.
I think vMix AVI codec will do it but on CPU only AFAIK with same quality as ProRes or DNxHD but less resource hungry.
thanks 2 users thanked DWAM for this useful post.
gotscottgreen on 8/11/2020(UTC), stigaard on 8/22/2020(UTC)
gotscottgreen
#3 Posted : Friday, July 31, 2020 3:58:56 AM(UTC)
gotscottgreen
I am a little above my level in what you are telling me. Is this a setting in FFMPEG for using NVENC, or do I have to "build my own" preset to get the 4:4:4 quality?
Sorry if I am a little obtuse on this. Really appreciate your help!!
Best
Xavier
#4 Posted : Friday, July 31, 2020 4:03:24 AM(UTC)
Check the file I referred to and compare its content to the FFMPEG recording settings in vMix, you will understand
gotscottgreen
#5 Posted : Wednesday, August 5, 2020 3:57:29 AM(UTC)
gotscottgreen
I have no clue how to do what you are talking about, I am not familiar with working with XML files or writing code for them.
Any help is appreciated.
Xavier
gotscottgreen
#6 Posted : Tuesday, August 11, 2020 3:28:06 AM(UTC)
gotscottgreen
Code:
For libx264
This is what is in my ffmpegformats.xml file, what and where would I add the above code you are mentioning?
Thanks so much in advance!!
<?xml version="1.0" encoding="UTF-8"?>
-<formats>
-<format>
<name>MPEG-2</name>
-<extensions>
<extension type="mpegts" ext=".ts" name="Transport Stream (.ts)"/>
<extension type="mpeg" ext=".mpg" name="Program Stream (.mpg)"/>
</extensions>
-<video codec="mpeg2video">
<bitRate>8M</bitRate>
<bitRate>10M</bitRate>
<bitRate>12M</bitRate>
<bitRate>15M</bitRate>
<bitRate>25M</bitRate>
<bitRate>50M</bitRate>
<bitRate>75M</bitRate>
</video>
-<audio codec="mp2">
<bitRate>384k</bitRate>
<bitRate>192k</bitRate>
<bitRate>128k</bitRate>
<bitRate>64k</bitRate>
</audio>
<command>-pix_fmt yuv420p -vcodec {video_codec} -maxrate:v {video_bitrate} -minrate:v {video_bitrate} -b:v {video_bitrate} -acodec {audio_codec} -b:a {audio_bitrate} -f {extension_type}</command>
<interlacedSupported/>
</format>
-<format>
<name>MP4 x264 AAC</name>
-<extensions>
<extension type="mp4 -movflags frag_keyframe" ext=".mp4" name="MP4"/>
<extension type="mp4" ext=".mp4" name="MP4 (Indexed)"/>
</extensions>
-<video codec="libx264">
<bitRate>6M</bitRate>
<bitRate>4M</bitRate>
<bitRate>2M</bitRate>
<bitRate>1500k</bitRate>
</video>
-<audio codec="libfaac">
</audio>
<command>-pix_fmt yuv420p -vcodec {video_codec} -preset:v veryfast -profile:v main -b:v {video_bitrate} -acodec {audio_codec} -b:a {audio_bitrate} -f {extension_type}</command>
</format>
-<format>
<name>MP4 x264 AAC Superfast</name>
-<extensions>
</extensions>
</video>
</audio>
<command>-pix_fmt yuv420p -vcodec {video_codec} -preset:v superfast -profile:v baseline -b:v {video_bitrate} -acodec {audio_codec} -b:a {audio_bitrate} -f {extension_type}</command>
</format>
-<format>
<name>MP4 NVENC AAC</name>
-<extensions>
</extensions>
-<video codec="nvenc">
</video>
</audio>
<command>-vcodec {video_codec} -pix_fmt:v nv12 -preset:v llhq -b:v {video_bitrate} -acodec {audio_codec} -b:a {audio_bitrate} -f {extension_type}</command>
</format>
-<format>
<name>ProRes</name>
-<extensions>
<extension type="mov -movflags frag_keyframe" ext=".mov" name="MOV"/>
<extension type="mov" ext=".mov" name="MOV (Indexed)"/>
</extensions>
-<video codec="prores">
<bitRate name="Proxy">0</bitRate>
<bitRate name="LT">1</bitRate>
<bitRate name="SQ">2</bitRate>
<bitRate name="HQ">3</bitRate>
</video>
-<audio codec="pcm_s16le">
<bitRate>PCM</bitRate>
</audio>
<command>-vcodec {video_codec} -profile:v {video_bitrate} -acodec pcm_s16le -f {extension_type}</command>
</format>
-<format>
<name>VC-3</name>
-<extensions>
<extension type="mxf" ext=".mxf" name="MXF"/>
</extensions>
-<video codec="dnxhd">
<bitRate name="220 1080 59.94i 29.97p">220M</bitRate>
<bitRate name="145 1080 59.94i 29.97p">145M</bitRate>
<bitRate name="45 1080 29.97p">45M</bitRate>
<bitRate name="185 1080 50i 25p">185M</bitRate>
<bitRate name="120 1080 50i 25p">120M</bitRate>
<bitRate name="36 1080 25p 24p">36M</bitRate>
<bitRate name="175 1080 24p">175M</bitRate>
<bitRate name="115 1080 24p">115M</bitRate>
<bitRate name="440 1080 59.94p">440M</bitRate>
<bitRate name="290 1080 59.94p">290M</bitRate>
<bitRate name="90 1080 59.94p">90M</bitRate>
<bitRate name="365 1080 50p">365M</bitRate>
<bitRate name="240 1080 50p">240M</bitRate>
<bitRate name="75 1080 50p">75M</bitRate>
<bitRate name="220 720 59.94p">220M</bitRate>
<bitRate name="145 720 59.94p">145M</bitRate>
<bitRate name="180 720 50p">180M</bitRate>
<bitRate name="120 720 50p">120M</bitRate>
<bitRate name="110 720 29.97p">110M</bitRate>
<bitRate name="75 720 29.97p">75M</bitRate>
<bitRate name="90 720 25p 24p">90M</bitRate>
<bitRate name="60 720 25p 24p">60M</bitRate>
</video>
</audio>
<command>-vcodec {video_codec} -b:v {video_bitrate} -acodec pcm_s16le -f {extension_type}</command>
</format>
</formats>
mavik
#7 Posted : Tuesday, August 11, 2020 6:58:57 AM(UTC)
mavik
in the libx264 section change from yuv420p to yuvj422p
gotscottgreen
#8 Posted : Wednesday, August 12, 2020 5:18:25 AM(UTC)
gotscottgreen
Thanks so much!! You mentioned that the NVENC encoders on the GPU card do 4:4:4 not 4:2:2, should I try that too? I was hoping to utilize the GPU for this if possible. I got a Quadro RTX4000 just for the 16 encoders in 1080p.
would I just add what you put above but with yuv444p?
Really appreciate your input!
Matej S
#9 Posted : Friday, April 9, 2021 12:22:47 AM(UTC)
Matej S
Czech Republic
Hi, thanks for tips there is my result:
Add this to your ffmpegformats.xml
for GPU acceleration 444:
<format>
<name>MP4 GPU444 NVENC AAC</name>
<extensions>
<extension name="MP4" ext=".mp4" type="mp4 -movflags frag_keyframe" />
<extension name="MP4 (Indexed)" ext=".mp4" type="mp4" />
</extensions>
</video>
</audio>
<command>-vcodec {video_codec} -pix_fmt:v yuv444p -preset:v llhq -profile:v high444p -b:v {video_bitrate} -acodec {audio_codec} -b:a {audio_bitrate} -f {extension_type}</command>
</format>
For CPU 422 acceleration:
<format>
<name>MP4 CPU422 x264 AAC</name>
<extensions>
</extensions>
</video>
</audio>
<command>-pix_fmt yuv422p -vcodec {video_codec} -preset:v veryfast -profile:v high422 -b:v {video_bitrate} -acodec {audio_codec} -b:a {audio_bitrate} -f {extension_type}</command>
</format>
