66 Pages«<4243444546>»
elgarf
#861 Posted : Saturday, August 8, 2020 4:56:12 PM(UTC)
elgarf
Russian Federation
Was thanked: 231 time(s) in 130 post(s)
There is no info about input category in API, as I see.
Papo
#862 Posted : Monday, August 10, 2020 11:45:51 PM(UTC)
Papo
Peru
Hello elgarf, excuse me if it is not this topic, I need your help, I beg you, could you please help me with this topic thank you https://forums.vmix.com/posts/t2...-encoded-in-visual-basic
elgarf
#863 Posted : Tuesday, August 11, 2020 5:47:42 PM(UTC)
elgarf
Russian Federation
@Papo, sent you PM.
Made some changes into how buttons handle images. Check Buttons2.vmc example.
Downloads
Universal Title Controller (updated 11.08.2020)
Changelog
thanks 2 users thanked elgarf for this useful post.
Chircanu on 8/11/2020(UTC), stigaard on 8/11/2020(UTC)
tomaszek117
#864 Posted : Wednesday, August 12, 2020 3:38:19 AM(UTC)
tomaszek117
Poland
Hi all,
Is it possible to do new line in Text Field, I mean that text will shown from new line in vMix?
elgarf
#865 Posted : Wednesday, August 12, 2020 1:05:03 PM(UTC)
elgarf
Russian Federation
@tomaszek117, right now it's not possible. But I can add it in the next release.
Not sure is it really needed.
xztraz
#866 Posted : Wednesday, August 12, 2020 11:18:56 PM(UTC)
xztraz
Sweden
i get a crash
make a button.
set button to update text field in a title to nothing. push button -> crash
using a space as text works and doesn't crash.
elgarf
#867 Posted : Wednesday, August 12, 2020 11:53:24 PM(UTC)
elgarf
Russian Federation
I'll look at this and fix.
Papo
#868 Posted : Thursday, August 13, 2020 8:52:44 AM(UTC)
Papo
Peru
hello thanks elgarf, it served me correctly without problems ...
xztraz
#869 Posted : Thursday, August 13, 2020 10:18:09 PM(UTC)
xztraz
Sweden
How do i get the state dependent led to work on a overlay?
I must say i'm generally impressed with UTC. Great program!
Also i'm trying to get a countdown clock to be able to set a start count down timer. would be great if the timer widget could do clock based countdown. but as a workaround i thought about making a button to just set a countdown time and text field to adjust it. but i can't use this for example {0:10:00 AM|mm:ss} in the text field in the script field.
elgarf
#870 Posted : Friday, August 14, 2020 3:14:55 AM(UTC)
elgarf
Russian Federation
@xztraz, that was my fault with State Dependent LED (it was always hidden). Now it should work.
Universal Title Controller (updated 13.08.2020)
You can use
Code:
{{0:11:00PM|mm:ss}}
That's because UTC internally use patterns like {0}, {1}, etc. So you must use {{ instead of {.
Or you can put just
Code:
{0:11:00PM|mm:ss}
into text field. But I think, it's better to make list widget, so you can made "presets" as predefined values.
xztraz
#871 Posted : Friday, August 14, 2020 10:14:07 AM(UTC)
xztraz
Sweden
{{0:11:00PM|mm:ss}} works beautiful. Thanks! yeah got some internal codes first instead of text. tried some other qualifiers like""
yes i want to switch between a clock countdown and timer countdown on the same title this makes it a bit easier with a basic preset :)
also indication leds (state dependent) now works too! Great! very quicky fixed
tomaszek117
#872 Posted : Sunday, August 16, 2020 7:11:04 AM(UTC)
tomaszek117
Poland
Thank You Elgarf, i think it would be usfull for example to add scorers in football to Bounded text and it would be showed one under previous scorer.
witsok
#873 Posted : Sunday, August 16, 2020 7:16:07 AM(UTC)
witsok
My UTC log file is full of such messages:
2020-08-15 16:16:13.9494 INFO Checking vMix server.
2020-08-15 16:16:13.9494 ERROR Error while connecting vMix server. System.Net.WebException: System.Net.Sockets.SocketException: Remote PC refuses connection 192.168.8.101:8088
UTC is running on the same laptop as vMix
Error messages appear when I change 192.168.8.101:8088 to 127.0.0.1
I checked the UTC log file because I keep experiencing the following situation
Simple soccer clock count up freezes for 2-3 seconds then resumes.
For example, when it turns 83:36 it stops and resumes from 83:38.
At first, I thought my laptop is struggling.
I am running many processes at the same time: streaming, recording.
So I stopped recording, but it didn't help.
When streaming and recording at the same time my CPU reaches 40-50%.
But render time goes up to 60-100 ms (it never happened before).
When recording is off render time is back to normal 10-20 ms, but the clock / timer still freezes now and then for a few seconds.
My laptop specs is as follows:
vMix ver 21 x 64
UTC ver 21
geforce gtx 765m
intel 4600
i7-4700mq (2.4 GHz)
SSD 120GB drive, another internal SSD is used for recording
hd 1000 gb
16GB RAM
win10
Any ideas of what's going on?
How can I solve the issue?
Witold
magicnb35
#874 Posted : Monday, August 17, 2020 11:48:00 AM(UTC)
magicnb35
Angola
SetTextColour error 2020-08-17_084253.png (32kb) downloaded 6 time(s).
elgarf
#875 Posted : Monday, August 17, 2020 4:32:59 PM(UTC)
elgarf
Russian Federation
@magicnb35, replace Functions.xml with this version
Functions.zip (11kb) downloaded 22 time(s).
@witsok, not sure why timer can be so laggy (it has highest priority). Is there a lot of buttons in your controller or something like that? What about UTC CPU/MEM usage?
thanks 1 user thanked elgarf for this useful post.
magicnb35 on 8/17/2020(UTC)
magicnb35
#876 Posted : Monday, August 17, 2020 6:17:49 PM(UTC)
magicnb35
Angola
I cannot shrink it vertically
elgarf
#877 Posted : Monday, August 17, 2020 6:59:29 PM(UTC)
elgarf
Russian Federation
@magicnb35, can you share this images?
It should take height from image size, but maybe there it's my bad somewhere in code.
magicnb35
#878 Posted : Tuesday, August 18, 2020 12:26:43 AM(UTC)
magicnb35
Angola
If me use the old version utc 7/2/2019 won't have that problem
elgarf
#879 Posted : Tuesday, August 18, 2020 12:39:29 AM(UTC)
elgarf
Russian Federation
It's still better give me images, so I can see where problem is.
Attach zip file, or write PM.
elgarf
#880 Posted : Tuesday, August 18, 2020 2:03:22 AM(UTC)
elgarf
Russian Federation
@magicnb35, looks like your images was really big. Hope I fixed handling them.
Downloads
Universal Title Controller (updated 17.08.2020)
magicnb35 on 8/18/2020(UTC)
Guest (18)
