gpdipalmerahtimur
#1 Posted : Monday, August 10, 2020 10:54:39 AM(UTC)
gpdipalmerahtimur
Indonesia
Currently I have a Stinger 1 Transition activated to a Background Input, so I have defined a Trigger inside that input to OverlayInputAllOff. Then I noticed during the Stinger, the Stinger itself also Turned Off. Does that function mean to remove Overlay 1-4 and also Stinger 1 & 2? Is this a bug or expected? My understanding is we want to remove every overlay (1-4) without affecting the Stinger.
Thanks in advance.
#2 Posted : Monday, August 10, 2020 4:46:55 PM(UTC)
Stinger 1 & 2 are Overlays 5 & 6 if you check the API's XML
gpdipalmerahtimur on 8/11/2020(UTC)
