OverlayInputAllOff Causing Stinger 1 to Off
Joined: 6/5/2020(UTC) Posts: 91  Location: Jakarta Thanks: 17 times Was thanked: 5 time(s) in 3 post(s)
Currently I have a Stinger 1 Transition activated to a Background Input, so I have defined a Trigger inside that input to OverlayInputAllOff. Then I noticed during the Stinger, the Stinger itself also Turned Off. Does that function mean to remove Overlay 1-4 and also Stinger 1 & 2? Is this a bug or expected? My understanding is we want to remove every overlay (1-4) without affecting the Stinger.
Thanks in advance.
Stinger 1 & 2 are Overlays 5 & 6 if you check the API's XML
