3rd Party Software and Development
Wireless Tally Light for $10 M5Stick-C (ESP32-Board) for vMix
Joined: 1/29/2018(UTC) Posts: 2 Location: Cleveland, OH
Joined: 7/15/2020(UTC) Posts: 7  Thanks: 1 times Was thanked: 1 time(s) in 1 post(s)
Originally Posted by: lpv  So, I tried using this version the other day but after flashing it to the m5stickc nothing happened, no message on the unit. I have no knowledge of these units so please bare with my ignorance. I noticed that I had to install the m5stack library to get your code to work. Is this not meant for the m5stickc? Would it work if i changed your code from #include <M5Stack.h> to m5stickc.h ? (I left the units at my place of worship but will try to flash them again soon). Also, to anyone worried about battery life. A simple solution (if you have the option) is to mount these over monitors that have USB power. I did this in our setup and it has worked out perfectly without needing to charge. I can even let the internal battery die on them and they will boot right up as soon as they draw power from the monitors.
Joined: 5/19/2017(UTC) Views messages in topic : 103   Location: The Netherlands Thanks: 15 times Was thanked: 36 time(s) in 24 post(s)
To resolve the battery issue, I use a small 1800mAh battery pack (Dutch link). I have a white one and I can use it for at least the length of a church service (1,5 to 2 hours). Haven't tried to drain the battery pack on Live mode yet. This battery pack looks even better, for only less than 1 euro extra. Just look around and see what's best for your situation.
 1 user thanked guidogast for this useful post.
Joined: 5/15/2011(UTC) Posts: 36  Location: south Korea Thanks: 3 times Was thanked: 1 time(s) in 1 post(s)
Hi guys. I received the ordered M5Stack-C. I installed Arduino 1.8.13 on my PC and also installed the library. By the way, M5Stack-c SW burning is the first time, so I don't understand. By step by step, is there an app site that I study? Would you please advise me. Best, julianlee
Originally Posted by: julianlee  Hi guys. I received the ordered M5Stack-C. I installed Arduino 1.8.13 on my PC and also installed the library. By the way, M5Stack-c SW burning is the first time, so I don't understand. By step by step, is there an app site that I study? Would you please advise me. Best, julianlee My holiday starts at the end of this week. I hope to fix a lot of the todo's that are still open. I'm also planning to do a complete tutorial from when the Stick arrives, without having the Arduino IDE installed. So I hope that that tutorial would fix your problem. However, I have a pretty busy life, so I can't promise anything, except that when I do it, I'll do my best!
Hi, Guidogast. That's very good news. Perhaps it is possible with your help. I am the old man of COBOL, FROTRAN generation. I would like to send you a gift after a good success.
 1 user thanked julianlee for this useful post.
Joined: 11/9/2014(UTC) Posts: 106   Location: Copenhagen, Denmark Thanks: 22 times Was thanked: 17 time(s) in 16 post(s)
Amazing stuff! I ordered some of the sticks. Looking forward to updates and trying it out myself :)
So here it is. A massive update to the project! Check the Github page for the latest and greatest features! A lot of thanks go to
alpval768
to point me to the preferences library. I hope to make the beginners tutorial very soon.
The tutorial is posted 😄. Check it on the main post of this thread, or on the GitHub page. I hope this helps:
julianlee
 M5StickC Tally (2).jpg (128kb) downloaded 13 time(s).It works very well. Thank you... MR. guidogast. Battery Support for M5stack will be reviewed when it arrives. (My order has been over a month, but the seller hasn't shipped it yet...)
Awesome Julian! I'm glad it's working for you. I just added new features. The Web UI now is dark and you can adjust the brightness of the LCD either via the stick itself or via the Web UI. Check GitHub for all the latest and greatest.
 2 users thanked guidogast for this useful post.
I had a productive day. Glad to announce:
- Battery indicator - On the fly tally number change - Landscape & Portrait mode
Clone/download master for latest features. Will create a new release tomorrow.
Alright, the last big feature is added: Multi tally support. The new release is published (v1.3), you can download it on GitHubAs of this moment, I'm not planning on adding a lot more new features unless it really adds more value to the project, it's my holiday after all 😅 Cheers! 🍻
Thanks! Looking forward to trying it out. Just waiting for the sticks to arrive :)
Hi, guidogast. Thanks to your help, it works very well. The m5stickc and battery stick are available 24 hours a day. If you have time, please review the contents below. This is an additional inquiry. Is it possible to add the sleep mode ON/OFF function to the web ui of m5stickc? ON: m5stickc screen clear mode. OFF: m5stick re-booting mode. If possible, various uncomfortable problems will be solved.  M5STICKC WITH STICK(Battery Support).jpg (26kb) downloaded 13 time(s).
Originally Posted by: julianlee  Hi, guidogast. Thanks to your help, it works very well. The m5stickc and battery stick are available 24 hours a day. If you have time, please review the contents below. This is an additional inquiry. Is it possible to add the sleep mode ON/OFF function to the web ui of m5stickc? ON: m5stickc screen clear mode. OFF: m5stick re-booting mode. If possible, various uncomfortable problems will be solved.  M5STICKC WITH STICK(Battery Support).jpg (26kb) downloaded 13 time(s). Hi Julian, Thanks for the feature request. What do you mean by Sleep Mode and Rebooting Mode?
1) Install more than 2ea m5stickc in a long and high distance indoors. Therefore, when restarting vmix or rebooting PC, tally cannot be directly linked. (M5stick must always be rebooted)
2) After the use of vmix, m5stick is displayed in the last state. It is difficult to reboot manually due to the installation location of the mtstick.
3) Therefore, because on/off/ is convenient in m5stick web ui... (Since the ip of vmix PC and m5stick are on the same internal ip, it is very easy to access m5stick web ui easily with Chrome browser)
4) Do you have any better ideas...? Best,
Just purchased a M5StickC PLUS. It should be more efficient and has a bigger screen resolution. I hope that I can check in code what board is being used, so I can change coordinates of the text on screen on the fly. Otherwise I'll make an option to use the PLUS or the original.
I ordered it on AliExpress, meaning it will arrive in about a month, so that's when I can start supporting the PLUS.
@julianlee Do you mean a reconnection button to vMix in the web interface? That would be easy to implement. I don't really get the on/off buttons that you describe.
Just pushed v1.4 to GitHub. 🐛 Fixed bug where Stick wouldn't show that it wasn't connected to vMix ⚡ Added Reconnect button to Web UI ⚡ Web UI now uses the Fetch API (the browser stays on the main page after clicking the save button)
Joined: 6/2/2020(UTC) Posts: 67   Location: Berlin Thanks: 8 times Was thanked: 9 time(s) in 8 post(s)
Hey GuidoGast what an awesome project.
What protocol do you harvest? On a forum entry from yesterday there was the question how to creatan an tricolor streamdeck button responding to tally data.
But i was unable read out data frrom the webcontroller page.
