#1 Posted : Saturday, July 25, 2020 6:10:38 PM(UTC)
Can we please consider have an optional separator selection ( , ; ) for importing CSV files in Data Sources
Not all CSV files are created equally when retrieved from various national areas
Tnx
mavik
#2 Posted : Monday, July 27, 2020 6:53:18 PM(UTC)
mavik
Was thanked: 193 time(s) in 173 post(s)
You can use notepad++ to search and replace. Takes 1 sec.
#3 Posted : Monday, July 27, 2020 7:05:11 PM(UTC)
On a local sourced one yes (would rather then adjust the source creator)
not if the data is coming in live from an external source
#4 Posted : Monday, July 27, 2020 7:12:51 PM(UTC)
+1
jedibrooker
#5 Posted : Friday, July 31, 2020 10:47:27 PM(UTC)
jedibrooker
Malaysia
+1 or even better a pipe "|"
#6 Posted : Friday, July 31, 2020 11:11:18 PM(UTC)
Better (selfish) or in addition to? ;-)
jedibrooker
#7 Posted : Friday, July 31, 2020 11:15:11 PM(UTC)
jedibrooker
Malaysia
of course, in addition too :)
we should be given a whole bunch of options or just the ability to specifiy which delimiter we need.
vmixLove33
#8 Posted : Monday, March 21, 2022 8:06:51 AM(UTC)
vmixLove33
+1
This is very important, we need to be able to specify what the delimiter is. (yes notepad++ can F/R but there are many valid reasons to be able to specify which delimiter to use, ie with Mult-Line "cells/fields" or with live/ http based CSV sources).
thank you!
Roy Sinclair
#9 Posted : Thursday, March 24, 2022 6:43:45 AM(UTC)
Roy Sinclair
Was thanked: 31 time(s) in 27 post(s)
Tnx
Since that's a Localization issue this might be better off written up as a bug needing fixing.
mavik
#10 Posted : Wednesday, November 23, 2022 3:54:46 AM(UTC)
mavik
+1
