Joined: 12/27/2012(UTC) Posts: 5,535  Location: Belgium Thanks: 319 times Was thanked: 1021 time(s) in 838 post(s)
Can we please consider have an optional separator selection ( , ; ) for importing CSV files in Data Sources
Not all CSV files are created equally when retrieved from various national areas
Tnx
You can use notepad++ to search and replace. Takes 1 sec.
Originally Posted by: mavik  You can use notepad++ to search and replace. Takes 1 sec. On a local sourced one yes (would rather then adjust the source creator) not if the data is coming in live from an external source
+1 or even better a pipe "|"
Originally Posted by: jedibrooker  +1 or even better a pipe "|" Better (selfish) or in addition to? ;-)
of course, in addition too :) we should be given a whole bunch of options or just the ability to specifiy which delimiter we need.
Thanks: 2 times Was thanked: 1 time(s) in 1 post(s)
+1 This is very important, we need to be able to specify what the delimiter is. (yes notepad++ can F/R but there are many valid reasons to be able to specify which delimiter to use, ie with Mult-Line "cells/fields" or with live/ http based CSV sources).
thank you!
Joined: 11/23/2020(UTC) Posts: 251  Location: Wichita Thanks: 14 times Was thanked: 32 time(s) in 28 post(s)
Originally Posted by: doggy  Can we please consider have an optional separator selection ( , ; ) for importing CSV files in Data Sources
Tnx Since that's a Localization issue this might be better off written up as a bug needing fixing.
Thanks: 64 times Was thanked: 159 time(s) in 143 post(s)
