Andreas
#1 Posted : Tuesday, July 28, 2020 12:10:16 AM(UTC)
Andreas
Germany
possibly a stupid question, but I haven't found an easy solution yet.
In a viritual studio, I have a main monitor and two small monitors. Suppose I have 3 guests and would like to jerk the active speaker into the main monitor, later switch the next speaker into the main monitor.
Is there an easy way to switch the sources in the main monitor and to automatically switch the previously active to the original small monitor.
So far I have opened the same studio three times, assigned the sources to each and jumped back and forth between the three studios.
Is there a way to toggle between the screens using buttons (e.g. 1, 2 & 3)?
Thank You!
#2 Posted : Tuesday, July 28, 2020 12:17:17 AM(UTC)
MovemultiviewOverlay shortcut
There is also SetMultiviewoverlay
elvis55 on 7/28/2020(UTC)
Andreas
#3 Posted : Tuesday, July 28, 2020 12:17:47 AM(UTC)
Andreas
Germany
configXML.txt (2kb) downloaded 9 time(s). Screenshot_2.png (785kb) downloaded 3 time(s). Screenshot_2.png (785kb) downloaded 6 time(s).
Andreas
#4 Posted : Tuesday, July 28, 2020 12:28:49 AM(UTC)
Andreas
Germany
Thank you!
But is that possible? The sources, positions etc. of the monitors are described in Config.xml and above that is the level with the monitor frames and above that the TalentA etc.
In addition, Multiview and I do not want to be friends because I do not know how I can save them properly for distribution.
I would like to be able to integrate and save the described functionality in the studio folder.
#5 Posted : Tuesday, July 28, 2020 12:32:38 AM(UTC)
A virtual set is a multiview ;-)
Andreas
#6 Posted : Tuesday, July 28, 2020 12:46:26 AM(UTC)
Andreas
Germany
Okay, where can I find more information to set this up without spamming this forum with dumb question?
#7 Posted : Tuesday, July 28, 2020 1:05:36 AM(UTC)
Your question was "In a viritual studio, I have a main monitor and two small monitors. Suppose I have 3 guests and would like to jerk the active speaker into the main monitor, later switch the next speaker into the main monitor.
and an answer was given. the answer basically is a replacement of the manual way to specify a input in your various virtual set locations
check out how to use shortcuts and specify inputs in virtual sets . vMix has tutorial videos about that (youtube)
the shortcut functions in your case mostly appropriate will be MovemultiviewOverlay and/or SetMultiviewoverlay
PS you posted 2 images , i assume to show the difference, but posted twice the same image
Andreas on 7/28/2020(UTC)
elvis55
#8 Posted : Tuesday, July 28, 2020 8:06:13 AM(UTC)
elvis55
Switzerland
SetMultiViewOverlay
#9 Posted : Tuesday, July 28, 2020 9:23:23 AM(UTC)
@ Andreas
Another option is to create 2nd and 3rd identical MultiViews (or Virtual Sets) except for who is in the #1 spot, as you have done, and use the Merge transition for a nice animated effect between them.
Andreas
#10 Posted : Thursday, July 30, 2020 8:29:33 AM(UTC)
Andreas
Germany
Originally Posted by: IceStream Go to Quoted Post
@ Andreas
That currently seems to be the only possible solution for my request. The commands I#m looking for would have to act on the XML of the studios, but not on the sources. Because a monitor in my setting (see picture) can be a guest, a desktop capture or whatever. Guests can change in one broadcast, so the source will do. With what I could learn with your help, I can change the current source, but not the screens (monitors 2 to 1Main, 1Main go 2 and so on).
The functionality of the config.xml should really be more extensive.
Or am I wrong?
Thank you for your thinking and your time!
#11 Posted : Thursday, July 30, 2020 8:45:38 AM(UTC)
@ Andreas
Or am I wrong?
yes you are wrong , and you don't even have to touch the config file
you have been given the shortut function , you have Ice's option or you can do it manually too (it's simpler than you believe it is ). To make it even more confusing one can use mini MIX into the game ;-)
ps. one can have multiple shortcut calls under the same key!
Andreas on 7/30/2020(UTC)
Andreas
#12 Posted : Thursday, July 30, 2020 9:07:42 AM(UTC)
Andreas
Germany
@ Andreas
Or am I wrong?
Okay, I just can't get it.
I already approached Tim with this matter at IBC 2019 (a trade fair in Amsterdam).
It doesn't seem as trivial as your answer sounds, because I haven't got a clear answer from him.
I was experimenting with the shortcuts you suggested. Unfortunately, I did not come to the result that I was looking for.
Cheers
-andreas
elvis55
#13 Posted : Thursday, July 30, 2020 4:11:45 PM(UTC)
elvis55
Switzerland
Hallo Digitaler Chronist,
Gute Sendung Gestern.
Das funktioniert mit "SetMultiViewOverlay".
Sie müssen jeweils 3 shortcuts mit derselben Taste erstellen. (Klonen), mit unterschiedlicher Konfiguration.
Die erste Zahl ist das Overlay dann ein Komma und die zweite Zahl ist der Eingang des Videos oder Kamera etc.
In Ihrem ConfigXML (welches ich runtergeladen hatte) ist
Screen1=Overlay5.
Screen2=Overlay6,
Screen3=Overlay7.
zb. Taste 1 = 5,1 Klonen, 6,2 Klonen 7,3
zb. Taste 2 = 5,3 Klonen, 6,1 Klonen 7,2
zb. Taste 3 = 7,1 Klonen, 6,3 Klonen 5,2
Somit wird beim jeweiligen Tastendruck jeder Eingang in einem anderen Screen angezeigt.
Gruss
Hello digital chronicler,
Good show yesterday.
That works with "SetMultiViewOverlay".
You have to create 3 shortcuts with the same key. (Cloning), with different configurations.
The first number is the overlay then a comma and the second number is the input of the video or camera etc.
In your ConfigXML (which I downloaded)
Screen1 = Overlay5.
Screen2 = Overlay6,
Screen3 = Overlay7.
e.g. Key 1 = 5.1 clones, 6.2 clones 7.3
e.g. Key 2 = 5.3 cloning, 6.1 cloning 7.2
e.g. Key 3 = 7.1 cloning, 6.3 cloning 5.2
This means that each input is displayed in a different screen each time the button is pressed.
Greeting
Image4.jpg (78kb) downloaded 0 time(s). Image2.jpg (111kb) downloaded 1 time(s). Image6.jpg (140kb) downloaded 1 time(s).
thanks 2 users thanked elvis55 for this useful post.
doggy on 7/30/2020(UTC), Andreas on 7/30/2020(UTC)
#14 Posted : Thursday, July 30, 2020 5:25:27 PM(UTC)
LOL Elvis55 , guess you were up earlier
Andreas
#15 Posted : Thursday, July 30, 2020 7:34:03 PM(UTC)
Andreas
Germany
Screen1=Overlay5.
Screen2=Overlay6,
Screen3=Overlay7.
zb. Taste 2 = 7,1 Klonen, 6,3 Klonen 5,2
Gruss
Screen1 = Overlay5.
Screen2 = Overlay6,
Screen3 = Overlay7.
e.g. Key 2 = 7.1 cloning, 6.3 cloning 5.2
Greeting
Hey elvis55, Danke für das Lob, ich gebe es weiter.
Vielen Dank für Deine Antwort. Das Problem mit "SetMultiViewOverlay" ist, dass der Befehl auf die Quellen zurückgreift. Wenn die Quelle jedoch eine andere Input Nummer/Namen hat, sind die Short Cuts hinfällig.
Ich suchte nach einem Workflow, wo ein Short Cut ausschließlich auf die Screen Anordnung zurückgreift, nicht aber auf die Quellen.
______
Hey elvis55, thanks for the praise, I will pass it to Thomas.
And many thanks for your response. The problem with "SetMultiViewOverlay" is that the command uses the sources. However, if the source has a different input number / name, the short cuts are not working anymore.
I was looking for a workflow where a short cut only change the screen arrangement but not the sources.
As already mentioned above, in my opinion the Config.xlm functionality should be more extensive or it would be nice if I could address a self-defined name of an VS screen position with a shortcut.
_____
Edit: Maybe i did a mistake. Will test it and come back with my result
elvis55
#16 Posted : Thursday, July 30, 2020 7:55:40 PM(UTC)
elvis55
Switzerland
MoveMultiViewOverlay
Example: 1,2 moves Overlay1 to Overlay2
FromIndex,ToIndex
Edit:
Sorry, wrong, does not work
thanks 1 user thanked elvis55 for this useful post.
#17 Posted : Thursday, July 30, 2020 8:27:16 PM(UTC)
Use a standard name in the shortcuts, rename the inputs accordingly , or have them always in the same position (quickly drag them there)
Then do setzoom and setpan on the inputs themselves then
want to have more fun ? do it all with a script , read the input data and rearrange
#18 Posted : Thursday, July 30, 2020 10:27:13 PM(UTC)
I guess it would be more of a problem if it wouldn't !
As Doggy suggested there are many ways to overtake this logical behaviour, be creative !
Guest (10)
