zeryab
#1 Posted : Thursday, February 6, 2014 5:18:08 AM(UTC)
zeryab
I used to run bambuser videos in vmix9 and vmix10 by adding a flash input with an address like the following example:
https://static.bambuser....r/player.swf?vid=4318931
This was working very well. Now in Vmix11, when I do the same, the video loads in the window but I can't play it by any mean.
Would you please check this and fix it?
Thanks.
Best Regards,
Zeryab
#2 Posted : Thursday, February 6, 2014 6:44:17 AM(UTC)
Could you try the vMix 12 beta:
http://forums.vmix.com.a....aspx?g=posts&t=1845
I have just tested the flash input and it is showing up ok.
zeryab
#3 Posted : Thursday, February 6, 2014 9:27:33 AM(UTC)
zeryab
Thank you for the reply.
Unfortunately it is not working well in Vmix12 as well.
Please see the below image. I used to play the video from the play button (the swf player) that is red circled in the image.
Best Regards,
Zeryab
#4 Posted : Thursday, February 6, 2014 10:23:08 AM(UTC)
Thanks,
I have found the bug and it will be fixed in the final vMix 12 release.
zeryab
#5 Posted : Thursday, February 6, 2014 11:52:55 AM(UTC)
zeryab
Thank you Martin. You are great. I will be waiting for the release of Vmix 12.
Guest (5)
