Hello, I used to run bambuser videos in vmix9 and vmix10 by adding a flash input with an address like the following example: https://static.bambuser....r/player.swf?vid=4318931This was working very well. Now in Vmix11, when I do the same, the video loads in the window but I can't play it by any mean. Would you please check this and fix it? Thanks. Best Regards, Zeryab
Joined: 1/13/2010(UTC) Posts: 5,367  Location: Gold Coast, Australia Was thanked: 4793 time(s) in 1645 post(s)
Thank you for the reply. Unfortunately it is not working well in Vmix12 as well. Please see the below image. I used to play the video from the play button (the swf player) that is red circled in the image.  Best Regards, Zeryab
Thanks,
I have found the bug and it will be fixed in the final vMix 12 release.
Martin vMix
Thank you Martin. You are great. I will be waiting for the release of Vmix 12.
