automatic overlayoff after a delay
Joined: 4/8/2019(UTC) Posts: 21  Thanks: 1 times Was thanked: 1 time(s) in 1 post(s)
hello, i created an animated title using gt titler and created a shortcup to display this title as an overlay. Now i try to have this title transition out automatically after a delay, but i don’t know how to this ?
Joined: 3/7/2012(UTC) Posts: 2,691  Location: Canada Thanks: 33 times Was thanked: 514 time(s) in 482 post(s)
@ plizon
You can set a "Duration" in milliseconds or Frames in the Overlay's Settings. Overlay button (at lower right) ===> Overlay dropdown menu (select channel of choice) ===> Duration field (default is 0 which is no limit or indefinite, but 8000 milliseconds will be 8 seconds, which is a common length for lower thirds)
Joined: 12/27/2012(UTC) Posts: 5,523  Location: Belgium Thanks: 318 times Was thanked: 1021 time(s) in 838 post(s)
One can also use a trigger on the title itself. On OverlayIn do a OverlayOut with a delay if it has to be for a specific title
Ice, Doggy,
thanks a lot for these tips. it was finally easy to perform ! As i’m a beginner in vmix, i still have a lot small details and settings to explore.
Joined: 3/28/2016(UTC) Posts: 171   Location: SACRAMENTO Thanks: 6 times Was thanked: 27 time(s) in 22 post(s)
Originally Posted by: doggy  One can also use a trigger on the title itself. On OverlayIn do a OverlayOut with a delay if it has to be for a specific title It must be one of those days but for the first time i'm creating a setup for someone else and i simply wanted to have one of my titles trigger OverlayOut but can't find it?? I can see a trigger for all overlays or a specific one but what if they brought it in on X overlay? Seems od to not be able to just execute itself out after so many seconds. I've used this software for years and for the first time i've run into this. i must be missing something. or is it that in order to have it auto out you must know what overlay it is coming in on? Basically its for an operator that might just bring the title in on any of the available overlay channels so i wanted to have it auto out after X seconds. Doesn't seem to exist unless i'm missing something :) thanks
@ NiBTour
Yeah, it is kind of tough to design something to cover all situations without it becoming extra complicated... Your options basically are to use the "OverlayInputAllOff" (which is not pretty) OR apply a Trigger for each Overlay channel (which will accomplish the goal, but will also remove all overlays on screen, and might not be desired) OR apply a duration to a particular channel that should only be used for that and similar Title Inputs OR make sure they only use a particular channel for that Title so that you can Trigger appropriately.
Thanks: 64 times Was thanked: 158 time(s) in 142 post(s)
