GT
GT Designer Download
Joined: 6/24/2020(UTC) Posts: 9  Location: New England
Is there a standalone download for GT Designer?
Joined: 12/27/2012(UTC) Posts: 5,523  Location: Belgium Thanks: 318 times Was thanked: 1021 time(s) in 838 post(s)
Originally Posted by: 911pro  Is there a standalone download for GT Designer? Been asked before in this forum
Joined: 3/7/2012(UTC) Posts: 2,691  Location: Canada Thanks: 33 times Was thanked: 514 time(s) in 482 post(s)
@ 911pro
Simple answer is NO, it only comes in the vMix Download and is available once vMix is activated. For the Standard GT Title Designer Edition (no animations) you can register for the FREE vMix Basic. For the Advanced GT Title Designer Edition you will need vMix 4K or vMix Pro.
Thank you for your prompt response. Additional favor. Still on GT Ticker 9 super Mega News. There is just one. Can they be multiple to select from. For example redline with the ticker is blurry can there be multiple instead of just one with red instead other colors as well. Gray, brown, white, Blue, green. I hope I make sense.
@ Daniel Funtong Make your own with the GT Title Designer: Ice
Joined: 5/15/2022(UTC) Posts: 39   Thanks: 6 times Was thanked: 1 time(s) in 1 post(s)
Originally Posted by: IceStream  @ Daniel Funtong Make your own with the GT Title Designer: Ice Hi ICE Is there any way to create an RTL Ticker Image in vmix ?
@ Winops Yes, you can set the direction to be left, right, up or down as mentioned at 3:45 in the video: ?t=224 Ice
Originally Posted by: IceStream  @ Winops Yes, you can set the direction to be left, right, up or down as mentioned at 3:45 in the video: ?t=224 Ice Hi ICE i saw that but the main problem is showing images at the end of each text parts of a ticker in vmix and then yes RTL tnx alot
Originally Posted by: Winops  Originally Posted by: IceStream  @ Winops Yes, you can set the direction to be left, right, up or down as mentioned at 3:45 in the video: ?t=224 Ice Hi ICE i saw that but the main problem is showing images at the end of each text parts of a ticker in vmix and then yes RTL in this sample used animated ticker on a wpf , but cant be directed like normal tickers  tickerwpf.PNG (66kb) downloaded 14 time(s).tnx alot
Originally Posted by: Winops  Hi ICE i saw that but the main problem is showing images at the end of each text parts of a ticker in vmix and then yes RTL in this sample used animated ticker on a wpf , but cant be directed like normal tickers
If you like this application but its lacking some functionality i sugest you contact the creator of the app . No one here will be able to fix that app here (also this is legacy XAML not GT title ) Or design own title in wpf ;-)
GT
