Apmoir
#1 Posted : Tuesday, July 28, 2020 10:49:53 PM(UTC)
Apmoir
Hi All
New to vmix so this may be a basic topic but I have setup a 30 second countdown timer for 30seconds. This needs to continuously loop. I clicked on the ‘loop’ option of the timer input but it doesn’t loop. It plays the first 30second iteration and then just stops. I assumed just pressing the loop option so it’s highlighted would be enough??
#2 Posted : Tuesday, July 28, 2020 10:57:29 PM(UTC)
Trigger on countdowncomplete startcountdown
Apmoir
#3 Posted : Tuesday, July 28, 2020 11:16:27 PM(UTC)
Apmoir
Thanks so much for quick response.
So I added this and assumed I added Timerclock to input. It gives me duration 500 as default? Mix defaults as 1. Value is empty.
But it doesn’t loop it? Just plays it once...
Also, why is it backwards on screen (I’m trying to use it using zoom).
Thank you again..
Apmoir
#4 Posted : Tuesday, July 28, 2020 11:20:37 PM(UTC)
Apmoir
Oh. Silly question. I set the default 500 to 0 and it worked. Duh.
However, why is it backwards?
Thanks thanks thanks
#5 Posted : Tuesday, July 28, 2020 11:33:38 PM(UTC)
Apmoir
#6 Posted : Tuesday, July 28, 2020 11:34:36 PM(UTC)
Apmoir
I am streaming it via Zoom and on Zoom the countdown clock is showing mirrored?
#7 Posted : Tuesday, July 28, 2020 11:55:00 PM(UTC)
for you or the viewers ?
but i didnt reference my ? to that
