Hi All
New to vmix so this may be a basic topic but I have setup a 30 second countdown timer for 30seconds. This needs to continuously loop. I clicked on the ‘loop’ option of the timer input but it doesn’t loop. It plays the first 30second iteration and then just stops. I assumed just pressing the loop option so it’s highlighted would be enough??
Trigger on countdowncomplete startcountdown
Thanks so much for quick response. So I added this and assumed I added Timerclock to input. It gives me duration 500 as default? Mix defaults as 1. Value is empty. But it doesn’t loop it? Just plays it once... Also, why is it backwards on screen (I’m trying to use it using zoom). Thank you again..
Oh. Silly question. I set the default 500 to 0 and it worked. Duh. However, why is it backwards?
Thanks thanks thanks
I am streaming it via Zoom and on Zoom the countdown clock is showing mirrored?
Originally Posted by: Apmoir  I am streaming it via Zoom and on Zoom the countdown clock is showing mirrored? for you or the viewers ? but i didnt reference my ? to that
