wscawebcast
#1 Posted : Wednesday, February 5, 2014 7:56:30 PM(UTC)
wscawebcast
How to reproduce:
- Create an input ("A") for an IP camera
- Create an input ("B") for a different IP camera
- Create an input ("Both") with "A" and "B" inputs added via MultiView
- Adjust the cropping for "A" and "B" in "Both" via Position
- Create an input ("C") with "Both" added via MultiView
Input "C" will not retain the crop settings from "Both". But if "A" and "B" are cropped in their own Main settings, then those crop settings carry through to "C".
#2 Posted : Thursday, February 6, 2014 12:55:38 AM(UTC)
Was thanked: 4727 time(s) in 1619 post(s)
Take a look at the screenshot below. I've created a setup as you describe
and the custom cropping in Both is displayed in C.
admin attached the following image(s):
wscawebcast
#3 Posted : Wednesday, February 12, 2014 2:27:37 AM(UTC)
wscawebcast
Martin, I'm still able to reproduce the issue. I'll send you a screenshot.
#4 Posted : Wednesday, February 12, 2014 9:45:48 AM(UTC)
Thanks,
I've found a bug which will be fixed in the final vMix 12.
mike16437
#5 Posted : Sunday, July 19, 2020 4:46:50 AM(UTC)
mike16437
I am having this same problem now in vMix 4K - 23.0.0.59 x64.
To recap, I've created multiple sources with an overlay, put those sources into another source via multiview, and the crop settings from the original source overlay are not transferring to the new source... Same as the OP in this thread.
Is there a fix for this?
Thank you!
Mike
#6 Posted : Sunday, July 19, 2020 1:26:33 PM(UTC)
Hi Mike,
The issue reported in this thread is a different issue that was resolved a few years back.
What you appear to be reporting is how cropping in vMix works, it will only crop the actual layer of that input
and not any sub inputs underneath it. This is done for performance reasons and there is no way around this at this time
other than to crop each input at the source.
mike16437 on 7/19/2020(UTC), eduardocfs on 7/28/2020(UTC)
mike16437
#7 Posted : Sunday, July 19, 2020 1:45:09 PM(UTC)
mike16437
Originally Posted by: admin Go to Quoted Post
Hi Mike,
Thank you, that's good information to have. I'll follow up with a separate thread for the issue I was trying to solve with this method.
-Mike
