Rank:: Member
Joined: 1/29/2014(UTC) Posts: 24  Location: Las Angeles, CA Was thanked: 3 time(s) in 3 post(s)
Users would like a little guidance on which video card does vMix recommend. Saying, "any modern fairly new card" is somewhat confusing. We want vMix's recommendation based on years of testing. I've listed the cards that Adobe recommends for optimal performance in Premiere Pro. My thought is if its good enough for Premiere Pro then it should run vMix just fine. Is this a fair assessment? Do you see a card on this list that you really like or dislike?
Adobe - Supported AMD and NVIDIA graphics cards for GPU acceleration
Windows CUDA: GeForce GT 650M GeForce GT 750M GeForce GTX 285 GeForce GTX 470 GeForce GTX 570 GeForce GTX 580 GeForce GTX 675MX GeForce GTX 680 GeForce GTX 680MX GeForce GTX 690 GeForce GTX 770 GeForce GTX 780 GeForce GTX TITAN Quadro CX Quadro FX 3700M Quadro FX 3800 Quadro FX 3800M Quadro FX 4800 Quadro FX 5800 Quadro 2000 Quadro 2000D Quadro 2000M Quadro 3000M Quadro 4000 Quadro 4000M Quadro 5000 Quadro 5000M Quadro 5010M Quadro 6000 Quadro K1100M Quadro K2000 Quadro K2100M Quadro K2000M Quadro K3000M Quadro K4000 Quadro K4100M Quadro K4000M Quadro K5000 Quadro K5000M Quadro K6000 Tesla C2050 Tesla C2070 Tesla C2075 Tesla M2050 Tesla M2070 Tesla K10
Mac CUDA: GeForce GTX 285 GeForce GTX 675MX GeForce GTX 680 GeForce GTX 680MX GeForce GT 650M GeForce GT 750M Quadro CX Quadro FX 4800 Quadro 4000 Quadro K5000
Thanks: 5 times Was thanked: 18 time(s) in 18 post(s)
Dear SKYGIF Going always in the way of what is the best card recommendation is not the good approach First of all, the development of Vmix gives us all the "requirement" hardware to work smoothly. I emphasize on Requirement because it was really tested with it, but many user using Vmix do not use exactly what it is recommended and have a best experience with this software. http://www.vmix.com.au/supported-hardware.aspxIt's not possible actually to test all hardware (Graphic card, Motherboard, Laptop, capture card, etc ...) and notice that depending on such or such configuration (Self-Build or not) one or other add-on hardware could be the best or the worst. See before the recommendation, any other card having this hardware capabilty in that requirement or better could be used. After then see what you want to do with vmix, check your budget and the hardware you are building for any compatibility issue and choose the card that respond to it. This is my Opinion Rgds C.
Rank:: Member
Thanks Charssay
I actually overlooked the page you linked to. That's a great start into figuring out where to start when building a system around vMix. The budget isn't a problem for me as long as I know what I'm buying. Ideally I want a graphics card that is great for vMix and Premiere Pro. I really wish vMix would sell "Ready To Go" racks that had everything you need for a 2, 4, or 8, camera shoot. (Excluding Cameras) I know it's software based but I must be missing something because I can't seem to get my webcam to activate inside vMix when Skype is occupying the cam. Seems like I need a piece of hardware. If you use vMix with Skype, how do you have it hooked in?
Dear SkyGif I Build personal unit for decade now, always according to what my customer need to do with it. And since I discover Vmix, I try to update those who need new set for recording In Live when they want to look at their cost (specialy chuch community), and whatever the software they will use. The best card your Adobe premiere will use, Vmix will deal with it. For Skype, I don't know, because I do not use it. Wait for someone in the forum that have done something, maybe it will help you If you want a System already set, there is this seller, http://streambreeze.net/ , You can try it if you want ... Rgds C.
 1 user thanked Charssay for this useful post.
Joined: 6/29/2011(UTC) Posts: 316   Location: Florida Thanks: 6 times Was thanked: 35 time(s) in 34 post(s)
Thank you Charssay for the mention. SkyGif, for vMix to see webcam change skype input to "vMix video" then webcam should be available to vMix as input. Also don't waist money on big powerful video card for Adobe PP the end results aren't that great. rather invest in a matrox I/O or BlackMagic Intensity I/O. These will give you much higher quality and faster rendering. If you are interested in a turnkey system that's proven to work please feel free to contact me. I have dozens of these that we have built for clients in the U.S. and Europe. BR Ed Griswold www.streambreeze.net
Rank:: Member
Thanks for the input! I use Premiere Pro more than vMix so I may have to buy a few extra CUDA cores. Thanks for the link. I will keep it in mind while I'm putting together a system that can edit 4k video smoothly, stream hd smoothly, and can capture program feeds smoothly. The computer isn't everything but its the hub. I want a solid hub then branch out with nice cameras and Black Magic gear.
My video card is old. Radeon 4890 and I haven't had a single problem with vMix. It's silky smooth. In Premiere Pro it's kinda glitchy on playback. I know there are a bunch of other factors but still the card is so old -2009- Windows 8 upgrade took 2 days of finagling.
