2 Pages<12
Kelvin
#21 Posted : Saturday, July 25, 2020 12:41:53 PM(UTC)
Kelvin
What Codec are you using under FFMPEG? The MP4 NVENC AAC codec uses the GPU. The others seem to use only the CPU. I didn't try all of them, but the one I tried did use the CPU and not the GPU.
ProSonas
#22 Posted : Saturday, July 25, 2020 5:04:24 PM(UTC)
ProSonas
Denmark
ProRes :)
nottooloud
#23 Posted : Tuesday, July 28, 2020 3:37:48 AM(UTC)
nottooloud
Originally Posted by: ProSonas Go to Quoted Post
We've been setting up the recording part using FFMPEG and I tried MP4 instead.
When doing the exact same thing (4k 50fps project, recording in 4k 50fps) the FFMPEG completely maxes out the PC where as a similar recording in MP4 reaches 5-10% of CPU.
Try vMix AVI. Should be even less.
sherifwassef
#24 Posted : Saturday, January 30, 2021 9:20:31 AM(UTC)
sherifwassef
Egypt
Simple Answer [Conclusion]
When you encode 4K video you must make sure that Hardware encoding is enabled and working. You should never encode 4k video on the CPU.
gzifcak
#25 Posted : Monday, February 8, 2021 4:23:37 AM(UTC)
gzifcak
Pro Res uses CPU, try H264 if you want to use GPU instead
Paul_WCP
#26 Posted : Thursday, February 25, 2021 8:12:01 PM(UTC)
Paul_WCP
Germany
Some good hints in this thread already. Here are my two cents.
Enable High Performance Input Mode in settings.
Make sure to not Encode more than 3 times with your GPU. (Usually thats enough. 1x Recording Cleanfeed 1x Record Dirty 1x Stream for example)
Your GPU has a turing chip that supports up to 3 encodes with its SoC NVENC.
https://developer.nvidia...e-gpu-support-matrix-new
NVENC only supports h264 and h265. Prores will use FFMPEG Encoding on your CPU.
https://developer.nvidia...m/nvidia-video-codec-sdk
Your system should easily handle your load.
Guest (7)
2 Pages<12
