vMix Call
vmix call - addinput
Joined: 11/19/2015(UTC) Posts: 30  Location: Netherlands Thanks: 1 times Was thanked: 3 time(s) in 3 post(s)
In the manual i only found the following options to AddInput via shortcut/script. However, did anyone find a way to add a new videocall via shortcut or script. I would like to program a button to add a new caller to the project.
Manual:
AddInput; Create a new Input based on information provided in Value.
Video|c:\path\to\video.avi Image|c:\path\to\image.jpg Photos|c:\path\to\folder Xaml|c:\path\to\title.xaml VideoList|c:\path\to\playlist.m3u Colour|HTMLColor AudioFile|c:\path\to\audio.wav Flash|c:\path\to\flash.swf PowerPoint|c:\path\to\powerpoint.pptx
 1 user thanked ovonder for this useful post.
not possible, what filename (password) would you use ?
the password is auto generated, so
VideoCall
would be enough. Or
VideoCall|Host => add a hosted input VideoCall|12312847 => to connect to an vmixcall station as client
Joined: 3/25/2020(UTC) Posts: 48  Location: Chichester Was thanked: 10 time(s) in 7 post(s)
If the option was available to addinput to create a Videocall then as mentioned the password is auto generated, you then easily query the API XML which would give you the input password which is the same as you create the video call manually.
So feature needs to be added to the - addinput
vMix Call
