ovonder
#1 Posted : Thursday, July 16, 2020 8:16:30 PM(UTC)
ovonder
In the manual i only found the following options to AddInput via shortcut/script.
However, did anyone find a way to add a new videocall via shortcut or script.
I would like to program a button to add a new caller to the project.
Manual:
AddInput; Create a new Input based on information provided in Value.
Video|c:\path\to\video.avi
Photos|c:\path\to\folder
Xaml|c:\path\to\title.xaml
VideoList|c:\path\to\playlist.m3u
Colour|HTMLColor
AudioFile|c:\path\to\audio.wav
Flash|c:\path\to\flash.swf
PowerPoint|c:\path\to\powerpoint.pptx
thanks 1 user thanked ovonder for this useful post.
maxdaniel98 on 8/20/2020(UTC)
#2 Posted : Thursday, July 16, 2020 8:22:11 PM(UTC)
not possible, what filename (password) would you use ?
ovonder
#3 Posted : Thursday, July 16, 2020 9:08:48 PM(UTC)
ovonder
the password is auto generated, so
VideoCall
would be enough.
Or
VideoCall|Host => add a hosted input
VideoCall|12312847 => to connect to an vmixcall station as client
Aecast
#4 Posted : Tuesday, July 21, 2020 2:15:46 AM(UTC)
Aecast
Was thanked: 10 time(s) in 7 post(s)
If the option was available to addinput to create a Videocall then as mentioned the password is auto generated, you then easily query the API XML which would give you the input password which is the same as you create the video call manually.
So feature needs to be added to the - addinput
