2 Pages12>
JohnnyBG
#1 Posted: : Sunday, July 19, 2020 3:41:00 AM(UTC)
JohnnyBG
If I stream to 3 destinations, is it possible to mute the audio to only one destination part way through the broadcast? It is necessary to mute singing when streaming to YouTube.
#2 Posted : Sunday, July 19, 2020 3:56:27 AM(UTC)
Mute the bus you are using for that stream (maybe route the audio to another bus first and use that for your YT stream)
JohnnyBG
#3 Posted : Sunday, July 19, 2020 6:14:15 AM(UTC)
JohnnyBG
How do I route the audio to another bus,
and will I need to do that for the other two?
elvis55
#4 Posted : Sunday, July 19, 2020 7:32:47 AM(UTC)
elvis55
Switzerland
Live Streaming 2
Souce Output 2
Audio Channels zb. Bus A
JohnnyBG
#5 Posted : Sunday, July 19, 2020 11:10:44 AM(UTC)
JohnnyBG
Not sure I understand.
dmwkr
#6 Posted : Sunday, July 19, 2020 3:09:35 PM(UTC)
dmwkr
- Enable an additional audio bus in Settings, Audio Outputs – say Bus A
- in the streaming settings of your YT stream set Channels to Bus A, the other streams will stay on Master
- in the Audio Mixer your Audio Sources that have the A activated besides the M will go to the YT stream
- there is a fader and mute button for Bus A. Use it when you want to mute your YT stream
JohnnyBG
#7 Posted : Sunday, July 19, 2020 9:01:21 PM(UTC)
JohnnyBG
Thanks, it works like a charm.
JohnnyBG
#8 Posted : Monday, July 20, 2020 8:39:03 PM(UTC)
JohnnyBG
I spoke too soon. It worked on the test bed computer. When I went to the production computer, there is no drop down choice in the streaming section.
I changed several things, but there is no channels drop down box. Do I need to change something?
#9 Posted : Monday, July 20, 2020 8:50:27 PM(UTC)
did you "- Enable an additional audio bus in Settings, Audio Outputs – say Bus A" ?
dmwkr on 7/20/2020(UTC)
dmwkr
#10 Posted : Monday, July 20, 2020 11:38:48 PM(UTC)
dmwkr
What doggy said. Otherwise, could you post a screenshot of your settings?
JohnnyBG
#11 Posted : Tuesday, July 21, 2020 12:09:00 AM(UTC)
JohnnyBG
In my settings for Audio output there is currently a Bus A and a Bus B, so I enabled Bus C. That didn't work, so I enabled Bus D and that didn't work.
I should say that there was a slider in the audio mixer when I enabled Bus C and Bus D. I can attach a shot of my settings. Assume you mean main settings plus the streaming menu (that did not have the channels selection).
Anything else that will be of help?
dmwkr
#12 Posted : Tuesday, July 21, 2020 12:12:01 AM(UTC)
dmwkr
Yes, the streaming settings, where the dropdown is missing, should be helpful.
#13 Posted: : Tuesday, July 21, 2020 12:21:24 AM(UTC)
Are both the same version and license type ?
JohnnyBG
#14 Posted : Tuesday, July 21, 2020 1:03:12 AM(UTC)
JohnnyBG
vmix HD, same license
DisasterMS
#15 Posted : Tuesday, July 21, 2020 4:57:54 AM(UTC)
DisasterMS
Location: 10271-A Trademark Street, Rancho Cucamonga, CA 91730, USA
JohnnyBG
#16 Posted : Tuesday, July 21, 2020 5:30:54 AM(UTC)
JohnnyBG
Here are the two screens
ONE
TWO
xaver
#17 Posted : Tuesday, July 21, 2020 6:10:11 AM(UTC)
xaver
One
Two
which vMix version?
elvis55
#18 Posted : Tuesday, July 21, 2020 6:28:05 AM(UTC)
elvis55
Switzerland
One
Two
which vMix version?
Version HD ??
xaver
#19 Posted : Tuesday, July 21, 2020 6:32:15 AM(UTC)
xaver
seems not be 23.xx (video source is missing)
JohnnyBG
#20 Posted : Tuesday, July 21, 2020 7:23:38 AM(UTC)
JohnnyBG
It is vMix HD 23.0.0.58
Guest (6)
2 Pages12>
