PTZ Optics focus not working
Thanks: 24 times Was thanked: 6 time(s) in 5 post(s)
<NOTE FROM UPDATE LOG added in version 20.0.0.51 * Added PTZ Focus support for cameras supporting VISCA over IP. (Includes NewTek PTZ Camera)
I just upgraded my PTZOptics 20x G2 firmware to the latest which is what is needed to run the NDI software upgrade. It seems that the "Focus" under PTZ settings does not work. I did not check this before I did the firmware upgrade. The tech specialist (Sean) at PTZoptics is aware of this as he tested it as well.
Joined: 1/13/2010(UTC) Posts: 5,312  Location: Gold Coast, Australia Was thanked: 4708 time(s) in 1613 post(s)
As mentioned in the log, Focus support is only for Sony VISCA over IP compatible cameras at this time. (Not to be confused with VISCA over UDP which is what the PTZ Optics cameras use)
There is a bug with the focus control in the PTZ Optics firmware which is why it is not currently supported, however we are working with them to resolve it and will post a software update when it is available.
Martin vMix
Thanks Martin - should have looked closer. BTW they also have a bug in their browser controller that does not keep auto focus off when using the pan/tilt buttons - it does work OK using the remote.
Joined: 5/27/2017(UTC) Posts: 93   Location: Greater St Louis Area Thanks: 67 times Was thanked: 20 time(s) in 13 post(s)
I'm having trouble creating a ShortCut that will use PTZFocusNear to quickly blur out. I've got three shortcuts on the same xKey: The First sets PTZFocusManual The Second should set PTZFocusNear to blur out quickly... "Value" here is in docs as Value,Input, Value=Speed. I've been using 0 or 1 for first, and have no idea what to do the specify the entire value for the field. In "Tiggers" I'd been able to make it work by going Near for 500 ms and then stopping. The Third sets PTZFocusStop
Another xKey Shortcut will set PTZFocusAuto so it snaps back in.
Anyone know what to do for the middle function?
Chad
Thanks: 1 times Was thanked: 5 time(s) in 5 post(s)
Any news about PTZ optics bug correction for manual focus ?
Joined: 8/24/2017(UTC) Posts: 21 Location: Madrid, Spain
Thanks: 1 times Was thanked: 7 time(s) in 7 post(s)
Joined: 8/2/2013(UTC) Posts: 1,096   Location: Fairhope, Alabama USA Thanks: 587 times Was thanked: 202 time(s) in 168 post(s)
That's a question best asked of PTZ Optics, don't you think?
- Tom
Originally Posted by: sinc747  That's a question best asked of PTZ Optics, don't you think?
- Tom I don't think so ... it currently works perfectly with Wirecast and Livestream Studio so it's a VMIX problem
Rank: Guest
Groups: Guests
I have the same problem too. Waiting for an update
Joined: 6/26/2020(UTC) Posts: 12  Location: Vermont Thanks: 3 times Was thanked: 1 time(s) in 1 post(s)
Originally Posted by: streammediaevent  Originally Posted by: sinc747  That's a question best asked of PTZ Optics, don't you think?
- Tom I don't think so ... it currently works perfectly with Wirecast and Livestream Studio so it's a VMIX problem New user, with a PTZO 20x, on the trial, deciding whether to spend $700 or not. Just ran into this issue which has been sitting here for (checks notes) 2 years. Should I be looking at other apps?
Joined: 7/28/2019(UTC) Posts: 351  Location: Santa Rosa Thanks: 1 times Was thanked: 53 time(s) in 51 post(s)
Personally, I would be looking at a hardware controller. Virtual controller tend to be sketchy no matter what.
Originally Posted by: Vince Beck  Personally, I would be looking at a hardware controller. Virtual controller tend to be sketchy no matter what. It's a computer responding to a well documented peripheral. Or not, as the case may be. Nothing virtual or more or less hardware about it.
Any news? Got a PTZ Optics 30X NDI and having issues trying to control focus through VMix.
Joined: 1/22/2020(UTC) Posts: 9  Location: California Was thanked: 1 time(s) in 1 post(s)
I am also eagerly awaiting this feature. I have setup vMix with PTZoptics in numerous locations for clients and all need the ability to save focus with virtual inputs.
Bumping this one. Still doesn't appear to work. Using older cameras that are now freaking out about AF and need more care and handling. This is very important going forward.
