FrankLeggett
#1 Posted : Friday, July 17, 2020 7:26:29 PM(UTC)
FrankLeggett
Can anyone help me with this. I would like my caption to show an image if an associated data cell has data in it.
For Example:
I would like to show a name on the screen with a coloured box behind it but if the data cell doesn't contain any data (Name) then not show the coloured box. I have tried using bounded boxes but if the data cell is empty there is still a very small coloured box which is the size of the bounding.
Like below.
Cell Boxes.jpg (51kb) downloaded 1 time(s).
#2 Posted : Friday, July 17, 2020 7:31:47 PM(UTC)
Use a script checking if there is data and instruct it to manipulate the image
FrankLeggett
#3 Posted : Friday, July 17, 2020 7:42:42 PM(UTC)
FrankLeggett
Do you mean VMix Scripting?
#4 Posted : Friday, July 17, 2020 7:56:31 PM(UTC)
yes
Lot depends on exactly what look you want, a obunded colored box, regular colored box, image ....
FrankLeggett
#5 Posted : Friday, July 17, 2020 8:14:34 PM(UTC)
FrankLeggett
Bounded boxes don't work because even if the cell is empty it still creates a tiny box based on the padding around the side. I think it will need to be a fixed length rectangle either a GT element or an image imported into the title but either way only made visible if the cell contains content.
FrankLeggett
#6 Posted : Friday, July 17, 2020 9:54:16 PM(UTC)
FrankLeggett
OK I have found a solution.
Create another cell in the data base and make it list an image conditional if the cell with text in is "Not Empty"
Example:
=IF(ISBLANK(D5),"","c:mypictures/Image.png")
Then create you Title with all the boxes in then link the image in Datasources to the cell with the formula in it.
I haven't found a way to use a GT Designer element yet or hide/unhide a GT Designer element.
thanks 1 user thanked FrankLeggett for this useful post.
doggy on 7/17/2020(UTC)
