GT
Image associated to data cell
Joined: 11/22/2018(UTC) Posts: 94  Location: Worthing Thanks: 1 times Was thanked: 4 time(s) in 3 post(s)
Hi, Can anyone help me with this. I would like my caption to show an image if an associated data cell has data in it. For Example: I would like to show a name on the screen with a coloured box behind it but if the data cell doesn't contain any data (Name) then not show the coloured box. I have tried using bounded boxes but if the data cell is empty there is still a very small coloured box which is the size of the bounding. Like below.  Cell Boxes.jpg (51kb) downloaded 1 time(s).
Use a script checking if there is data and instruct it to manipulate the image
Do you mean VMix Scripting?
Originally Posted by: FrankLeggett  Do you mean VMix Scripting? yes Lot depends on exactly what look you want, a obunded colored box, regular colored box, image ....
Bounded boxes don't work because even if the cell is empty it still creates a tiny box based on the padding around the side. I think it will need to be a fixed length rectangle either a GT element or an image imported into the title but either way only made visible if the cell contains content.
OK I have found a solution.
Create another cell in the data base and make it list an image conditional if the cell with text in is "Not Empty"
Example: =IF(ISBLANK(D5),"","c:mypictures/Image.png")
Then create you Title with all the boxes in then link the image in Datasources to the cell with the formula in it.
I haven't found a way to use a GT Designer element yet or hide/unhide a GT Designer element.
 1 user thanked FrankLeggett for this useful post.
GT
