puruzio
#1 Posted : Monday, July 13, 2020 2:19:34 AM(UTC)
puruzio
I have a video (mp4) input that needs to fade into another camera input upon completion. I know it can be achieved using a trigger.
What makes it tricky though is that it's a multiview containing the video that needs to be triggered to transition out (in this multiview, the video is zoomed out and the outer space is filled with an image), so the trigger setting for the video itself has no impact on the multiview.
It feels that this is a scenario so common that vMix would already have a solution for it.
Thanks in advance.
PS. As long as I can give a video an image background, I don't have to use a multiview. Just mentioning this in case there is a way to achieve this triggered transition in a totally different approach.
#2 Posted : Monday, July 13, 2020 3:04:56 AM(UTC)
Maybe using a OnCountdownCompleted trigger (as you know this video duration) ?
However if you want a transition effect within this multiview, you have to use a Mix input which unfortunately is not video file friendly...
puruzio on 7/13/2020(UTC)
dmwkr
#3 Posted : Monday, July 13, 2020 3:13:34 AM(UTC)
dmwkr
Was thanked: 154 time(s) in 138 post(s)
Or maybe:
- Create virtual input of video
- Multiview Layer 1 on original video: Background image
- Multiview Layer 2 on original video: Virtual input of video
- Set trigger OnCompletion on the original video
thanks 4 users thanked dmwkr for this useful post.
DWAM on 7/13/2020(UTC), doggy on 7/13/2020(UTC), puruzio on 7/13/2020(UTC), gez737 on 5/4/2022(UTC)
#4 Posted : Monday, July 13, 2020 3:15:17 AM(UTC)
or if duration is not known a script to check the duration and initiate a countdown or check the end of the video and act upon
#5 Posted : Monday, July 13, 2020 3:17:31 AM(UTC)
@dmwkr
Smart! I think this should work
EDIT : Just checked, it works!
EDIT 2 : The OnCountdownCompleted method works too but it's less convenient
dmwkr on 7/18/2020(UTC)
puruzio
#6 Posted : Monday, July 13, 2020 4:04:34 AM(UTC)
puruzio
Cool~ Thank you all!
gez737
#7 Posted : Wednesday, May 4, 2022 7:37:36 PM(UTC)
gez737
Just a quick huge thanks to @dmwkr.
just what I needed! Brillant.
Good old vMix Forum and Google search!
