Feature Requests
30/60 FPS on the "New Preset" dropdown
Joined: 7/6/2020(UTC) Posts: 5  Was thanked: 1 time(s) in 1 post(s)
Hope you're all doing well and staying safe.
Most of my projects are either 30 or 60 FPS. However, the options available whenever I create a new presets the options available in the dropdown list don't include any 30 or 60 FPS options. I always end up either closing/opening vMix (in which case vMix starts up with a black preset at the same resolution frame rate of the last opened preset) or I create a new one, randomly select a preset, then change it after vMix restarts.
Would it be possible to include 30/60 FPS options?
Thanks!
Stay safe!
Johnny
Joined: 4/23/2017(UTC) Posts: 1,478  Location: Germany Thanks: 3 times Was thanked: 193 time(s) in 173 post(s)
Settings - Display - Master Frame rate: I have all of these available. I might miss an important part of your issue.
@mavik Thank you for your reply. I'm referring to the scenario when you press the [NEW] button on the top left of the vMix window (next to "Preset"). Pressing this button displays a popup window with a drop down. None of the options listed in the dropdown include 30 or 60 FPS. So, I end up selecting the closes one and the go to "Settings - Display - Master Frame rate" as you suggested.
I'm suggesting we should have 30/60 FPS options in that dropdown, thus eliminating the need to have to change it after the fact.
I hope this explains it.
Thanks!
OK, got it. I can follow. I think this is really minor. As we both know to "fine tune" it I don't believe there is really an issue.
You’re right. It is minor, but it’s still a valid feature request.
Feature Requests
