johnny@estilles.com
#1 Posted : Monday, July 6, 2020 7:31:56 PM(UTC)
johnny@estilles.com
Philippines
Hope you're all doing well and staying safe.
Most of my projects are either 30 or 60 FPS. However, the options available whenever I create a new presets the options available in the dropdown list don't include any 30 or 60 FPS options. I always end up either closing/opening vMix (in which case vMix starts up with a black preset at the same resolution frame rate of the last opened preset) or I create a new one, randomly select a preset, then change it after vMix restarts.
Would it be possible to include 30/60 FPS options?
Thanks!
Stay safe!
Johnny
mavik
#2 Posted : Tuesday, July 7, 2020 12:19:13 AM(UTC)
mavik
Settings - Display - Master Frame rate: I have all of these available. I might miss an important part of your issue.
johnny@estilles.com
#3 Posted : Tuesday, July 7, 2020 10:54:05 AM(UTC)
johnny@estilles.com
Philippines
@mavik Thank you for your reply. I'm referring to the scenario when you press the [NEW] button on the top left of the vMix window (next to "Preset"). Pressing this button displays a popup window with a drop down. None of the options listed in the dropdown include 30 or 60 FPS. So, I end up selecting the closes one and the go to "Settings - Display - Master Frame rate" as you suggested.
I'm suggesting we should have 30/60 FPS options in that dropdown, thus eliminating the need to have to change it after the fact.
I hope this explains it.
Thanks!
mavik
#4 Posted : Tuesday, July 7, 2020 7:03:01 PM(UTC)
mavik
OK, got it. I can follow. I think this is really minor. As we both know to "fine tune" it I don't believe there is really an issue.
johnny@estilles.com
#5 Posted : Friday, July 17, 2020 6:55:31 PM(UTC)
johnny@estilles.com
Philippines
You’re right. It is minor, but it’s still a valid feature request.
