[HELP ]How to Resize Input by Vmix like this
Joined: 6/11/2020(UTC) Posts: 5  Location: ho chi minh Thanks: 3 times
I try lots of way to change size of input for multiview like this.But i fail Help me pls  Capture.jpg (1,010kb) downloaded 9 time(s).
Thanks: 4 times Was thanked: 8 time(s) in 7 post(s)
The best way is probably to create 2 seperate key/fill Mask files. 1 file for each input. and then create a virtual input of the inputs you use and use the key/fill there https://www.vmix.com/hel...utSettingsColourKey.htmlKey/Fill Input Select another input to use as the Key channel for this input. The input selected should be grey scale with black representing fully transparent (0) and white as opaque (255). 1 mask file might even be enough as you only need to do it to the input that is on top.
 1 user thanked ggudnason for this useful post.
Originally Posted by: ggudnason  The best way is probably to create 2 seperate key/fill Mask files. 1 file for each input. and then create a virtual input of the inputs you use and use the key/fill there https://www.vmix.com/hel...utSettingsColourKey.htmlKey/Fill Input Select another input to use as the Key channel for this input. The input selected should be grey scale with black representing fully transparent (0) and white as opaque (255). 1 mask file might even be enough as you only need to do it to the input that is on top.  123.JPG (159kb) downloaded 8 time(s).I do following you, i have been resize of it but i cant merge it together like this - cant overlay and multiview [HeLP me]
here is a screenshot of what I hacked together  Untitled2.png (46kb) downloaded 12 time(s).
Originally Posted by: ggudnason  here is a screenshot of what I hacked together  Untitled2.png (46kb) downloaded 12 time(s). thank you very much i did it
Joined: 10/23/2015(UTC) Posts: 458   Thanks: 20 times Was thanked: 231 time(s) in 130 post(s)
I just made example of Virtual Set with this type of resizing. I think, this is easier, than masks.  45 Degree.zip (45kb) downloaded 19 time(s).
 2 users thanked elgarf for this useful post.
Originally Posted by: elgarf  I just made example of Virtual Set with this type of resizing. I think, this is easier, than masks.  45 Degree.zip (45kb) downloaded 19 time(s). Can you explain clearly ? :( ihave been down it but i dont know how
Quote:Can you explain clearly ? :( ihave been down it but i dont know how
