vipro142
#1 Posted : Tuesday, June 30, 2020 12:37:41 PM(UTC)
vipro142
Viet Nam
I try lots of way to change size of input for multiview like this.But i fail
Help me pls
ggudnason
#2 Posted : Tuesday, June 30, 2020 5:13:06 PM(UTC)
ggudnason
Was thanked: 8 time(s) in 7 post(s)
The best way is probably to create 2 seperate key/fill Mask files. 1 file for each input. and then create a virtual input of the inputs you use and use the key/fill there
https://www.vmix.com/hel...utSettingsColourKey.html
Key/Fill Input
Select another input to use as the Key channel for this input.
The input selected should be grey scale with black representing fully transparent (0) and white as opaque (255).
1 mask file might even be enough as you only need to do it to the input that is on top.
thanks 1 user thanked ggudnason for this useful post.
vipro142 on 6/30/2020(UTC)
vipro142
#3 Posted : Tuesday, June 30, 2020 8:59:57 PM(UTC)
vipro142
Viet Nam
Key/Fill Input
I do following you, i have been resize of it but i cant merge it together like this - cant overlay and multiview
[HeLP me]
ggudnason
#4 Posted : Tuesday, June 30, 2020 10:59:31 PM(UTC)
ggudnason
here is a screenshot of what I hacked together
vipro142 on 7/1/2020(UTC)
vipro142
#5 Posted : Wednesday, July 1, 2020 5:32:11 PM(UTC)
vipro142
Viet Nam
thank you very much i did it
elgarf
#6 Posted : Saturday, July 4, 2020 3:06:01 AM(UTC)
elgarf
Russian Federation
Was thanked: 231 time(s) in 130 post(s)
I just made example of Virtual Set with this type of resizing. I think, this is easier, than masks.
45 Degree.zip (45kb) downloaded 19 time(s).
thanks 2 users thanked elgarf for this useful post.
doggy on 7/4/2020(UTC), vipro142 on 7/4/2020(UTC)
vipro142
#7 Posted : Saturday, July 4, 2020 4:13:01 AM(UTC)
vipro142
Viet Nam
Can you explain clearly ? :( ihave been down it but i dont know how
#8 Posted : Saturday, July 4, 2020 4:17:55 AM(UTC)
Guest (6)
