davenv
#1 Posted : Monday, June 29, 2020 1:43:02 AM(UTC)
davenv
If I connect cameras to vMix using a HDMI to USB capture card the image stutters and there is a lot of lag (there is very little when connecting webcams). If, however, I connect it to OBS and then use the OBS Camera in vMix the image is smooth, though with latency. Can anyone suggest a fix?
boris9831
#2 Posted : Saturday, July 4, 2020 10:43:04 AM(UTC)
boris9831
Had the same problem and when I set the input to 1920x1080 MJPG it solved the problem. BTW, I just got a USB capture device for $27 on Amazon see https://amzn.to/3eTtLxI. I cannot believe the performance with a JVC 310 (camcorder) . The latency is within a frame or 2 of my Magewell 4 port PCI capture card. I will be posting some latency numbers compared to NDI shortly.
