Feature Requests
Scripting Feature Request
Joined: 5/7/2020(UTC) Posts: 7  Location: St Ann Was thanked: 3 time(s) in 1 post(s)
I create and work with a lot of Scripts in vMix, currently I have over 30 that I use depending on the project. The Downside is that my config file keeps growing bigger and bigger. These are a couple New Features I'd like to see added: - Ability to designate whether the Script is Local (to current Present) or Global. Just Like Shortcuts.
- Ability to Export & Import a selection of Scripts (All, Selected Only)
Thanks Martin! Am Enjoying how easy vMix makes my life
 3 users thanked LiveStreamingJamaica for this useful post.
Joined: 2/18/2018(UTC) Posts: 42  Thanks: 8 times Was thanked: 2 time(s) in 2 post(s)
Joined: 2/12/2020(UTC) Posts: 10  Location: Florida Thanks: 2 times Was thanked: 1 time(s) in 1 post(s)
I like that idea, but I'd take it a step further and have the option for the scripts to be kept as external files if you choose, which will naturally reduce the size of the config. I have all of my scripts saved as vb in the file system as a backup and for easier editing.
Joined: 12/27/2012(UTC) Posts: 5,513  Location: Belgium Thanks: 318 times Was thanked: 1021 time(s) in 838 post(s)
Joined: 3/12/2015(UTC) Posts: 482  Location: Kansas City, MO USA Thanks: 152 times Was thanked: 76 time(s) in 57 post(s)
+1 Having the scripts in the project would be a big deal. System wide scripts don't make a lot of sense in our workflow. Having them external would be huge, and really help the casual users, by being able to share easily.
What would be cool is to have them be like "inputs" in a project when it comes to Opening and Appending a project.
Joined: 5/10/2020(UTC) Posts: 104   Location: Sacramento, California Thanks: 13 times Was thanked: 5 time(s) in 5 post(s)
Joined: 11/9/2018(UTC) Posts: 57  Location: Vårgårda Thanks: 21 times Was thanked: 2 time(s) in 1 post(s)
Thanks: 64 times Was thanked: 157 time(s) in 141 post(s)
Joined: 1/25/2019(UTC) Posts: 330  Thanks: 23 times Was thanked: 84 time(s) in 64 post(s)
Joined: 4/23/2017(UTC) Posts: 1,463  Location: Germany Thanks: 3 times Was thanked: 193 time(s) in 173 post(s)
FYI Quote:Ability to designate whether the Script is Local (to current Present) or Global. Just Like Shortcuts. Is avaialbel in latest v24 early preview! Based on that Quote:I like that idea, but I'd take it a step further and have the option for the scripts to be kept as external files if you choose, which will naturally reduce the size of the config. I have all of my scripts saved as vb in the file system as a backup and for easier editing. Its has become easier to "archive" them by pulling them from the preset file (an XML reader). Was possible from the config file too just a bit more complicated
Joined: 10/25/2018(UTC) Posts: 43  Location: Moscow Thanks: 8 times Was thanked: 4 time(s) in 3 post(s)
 2 users thanked doggy for this useful post.
Joined: 11/21/2017(UTC) Posts: 124  Location: Philadephia, PA Thanks: 31 times Was thanked: 14 time(s) in 9 post(s)
Joined: 3/23/2020(UTC) Posts: 139  Location: Washington, DC Thanks: 41 times Was thanked: 25 time(s) in 17 post(s)
Feature Requests
