Hello Guys
i was wondering if you can add support to control an input position / zoom / cropping (over a certain time) in scripting,, that would be really helpful to build some powerful transitions and DVEs
Thanks Haitham
No they do not exist in scripting !! maybe you are talking about something else,
i already contacted support by email on another issue and i asked them for this,, and below you can see thier reply
"There is not currently a way to adjust position settings, such as cropping via the Scripting or Shortcut functions at this time. However if you ever see any potential new features you would like added to vMix, we recommend submitting a post to our feature request forums"
Joined: 5/10/2020(UTC) Posts: 104   Location: Sacramento, California Thanks: 13 times Was thanked: 5 time(s) in 5 post(s)
Thanks Haitham Haitham, have you tried building two different inputs with the start point and end point and doing a merge transition between them?
Joined: 12/27/2012(UTC) Posts: 5,509  Location: Belgium Thanks: 316 times Was thanked: 1021 time(s) in 838 post(s)
Like Geoff says , try merging And one can also use basic virtual sets with shortcuts to go to various zoomed and cropped positions and while there is no shortcut for cropping there are for zoom and pan
Thank you so much for your reply,, i will try it today,
