Haitham
#1 Posted : Wednesday, June 24, 2020 2:05:13 PM(UTC)
Haitham
Hello Guys
i was wondering if you can add support to control an input position / zoom / cropping (over a certain time) in scripting,, that would be really helpful to build some powerful transitions and DVEs
Haitham
Haitham
#2 Posted : Wednesday, June 24, 2020 5:17:49 PM(UTC)
Haitham
No they do not exist in scripting !! maybe you are talking about something else,
i already contacted support by email on another issue and i asked them for this,, and below you can see thier reply
"There is not currently a way to adjust position settings, such as cropping via the Scripting or Shortcut functions at this time. However if you ever see any potential new features you would like added to vMix, we recommend submitting a post to our feature request forums"
Geoff B
#3 Posted : Wednesday, June 24, 2020 11:13:11 PM(UTC)
Geoff B
Originally Posted by: Haitham Go to Quoted Post
Hello Guys
Haitham
Haitham, have you tried building two different inputs with the start point and end point and doing a merge transition between them?
#4 Posted : Thursday, June 25, 2020 12:27:34 AM(UTC)
Like Geoff says , try merging
And one can also use basic virtual sets with shortcuts to go to various zoomed and cropped positions
and while there is no shortcut for cropping there are for zoom and pan
Haitham
#5 Posted : Thursday, June 25, 2020 1:20:28 AM(UTC)
Haitham
Thank you so much for your reply,, i will try it today,
