66 Pages«<3940414243>»
Le-bo2d9
#801 Posted : Friday, June 12, 2020 3:19:56 AM(UTC)
Le-bo2d9
This is wwhat i found in the log file
elgarf
#802 Posted : Saturday, June 13, 2020 5:40:53 PM(UTC)
elgarf
Russian Federation
Was thanked: 231 time(s) in 130 post(s)
Some new updates with volume widget.
+ Toggles for audiobusses for volume widget
+ Toggle for mute input/bus for volume widget
+ Hotkeys for volume widget
+ Hotkeys section into widget properties now collapsable
Universal Title Controller (updated 13.06.2020)
thanks 2 users thanked elgarf for this useful post.
DWAM on 6/13/2020(UTC), Chircanu on 6/14/2020(UTC)
Chircanu
#803 Posted : Sunday, June 14, 2020 3:47:48 AM(UTC)
Chircanu
Thanks a lot for the update, but I have a problem. I tried to use a file saved with an earlier version and it doesn't work. Thanks again!This is the contents of the log file
2020-06-13 20:46:48.5450 INFO Loading mapped functions.
2020-06-13 20:46:48.5849 INFO Loading templates.
2020-06-13 20:46:48.7255 INFO Searching for data providers.
2020-06-13 20:46:48.9589 INFO Loading window settings.
elgarf
#804 Posted : Sunday, June 14, 2020 4:35:37 AM(UTC)
elgarf
Russian Federation
@Chircanu, send me this file, please. Maybe it's because I've renamed Slider to Volume, so I can fix it.
I've fixed it, I think. Re-download, please, this version. I'll made update check function into UTC in the next version. So you can be up-to-date without reading first post =)
Chircanu
#805 Posted : Sunday, June 14, 2020 6:01:26 AM(UTC)
Chircanu
Hi again, I tried again, unfortunately it still doesn't work with a previously saved file. Thanks for the promptness with which you responded
desmar
#806 Posted : Sunday, June 14, 2020 6:02:58 AM(UTC)
desmar
Canada
When adding a timer widget, it causes vMixUTC to "not responding" and then crash with 6/13/2020 version. Tried cloning github source and recompile in Visual Studio 2019 and get the same result.
thanks 1 user thanked desmar for this useful post.
elgarf on 6/14/2020(UTC)
elgarf
#807 Posted : Sunday, June 14, 2020 2:36:52 PM(UTC)
elgarf
Russian Federation
@Chircanu, maybe it's because broken timer widget. I'll fix it today.
Timer widget now should work ok.
Universal Title Controller (updated 14.06.2020)
thanks 1 user thanked elgarf for this useful post.
Chircanu
#808 Posted : Sunday, June 14, 2020 4:15:18 PM(UTC)
Chircanu
Hello everyone, hello @ elgarf, after the new update (14.06.2020) I can confirm the good functionality. Thanks again and a wonderful day!
Le-bo2d9
#809 Posted : Monday, June 15, 2020 5:58:26 PM(UTC)
Le-bo2d9
Hi Chircanu, what is not working?
I have the "problem" that the NDI nomitor is not working with priviously save files. But this is because i leave the version name in the directory and then the NDI monitor module is looking for the dll at the wrong place. When I go to the properties of the NDI monitor and I change the path name to the correct one. Than the NDI monitor is working again.
Kind Regards
Koen
ALICIOV
#810 Posted : Thursday, June 18, 2020 10:38:12 PM(UTC)
ALICIOV
Views messages in topic : 4
Romania
how to change colors using GT Designer on score board
elgarf
#811 Posted : Friday, June 19, 2020 3:32:24 PM(UTC)
elgarf
Russian Federation
@ALICIOV, you can't dynamically change colors in GT Titles, as far as I know.
I've made a lot of changes. Not sure they are all useful, so try them and decide =)
Universal Title Controller (updated 19.06.2020)
Changelog
19.06.2020:
+ Excel Data Provider
+ Conception of "Pages" - now user have Main and Data pages. On data page user can place widgets, which are not needed in production. Like buttons, which are used only with ExecLink or proxy text fields
+ Button script logger for debugging your scripts
+ Icon with (?) which should be helpful for beginners
+ Redesign of settings and static variables
! Fixed bug with mappings, active after widget deleting
! Bugfixes
ALICIOV on 6/19/2020(UTC), Chircanu on 6/20/2020(UTC)
ALICIOV
#812 Posted : Friday, June 19, 2020 6:02:57 PM(UTC)
ALICIOV
Romania
elgarf, soryy how to create colors using GT Designer on score board
elgarf
#813 Posted : Friday, June 19, 2020 6:51:49 PM(UTC)
elgarf
Russian Federation
@ALICIOV, I think questions about GT better post into GT subforum.
https://forums.vmix.com/topics/12-GT
Still can't understand what you want to make =(
JAIRODJ
#814 Posted : Saturday, June 20, 2020 2:15:10 AM(UTC)
JAIRODJ
Was thanked: 16 time(s) in 12 post(s)
Thanking you for your great work @elgarf.
I have tried to use excel data in a similar way to xml, but when adding the filepatch, UTC closes automatically.
I don't know if I'm doing the right thing or if the app has a bug.
LOG
2020-06-19 11:13:07.3281 INFO Loading mapped functions.
2020-06-19 11:13:07.3790 INFO Loading templates.
2020-06-19 11:13:07.5539 INFO Searching for data providers.
2020-06-19 11:13:07.7688 INFO Loading window settings.
2020-06-19 11:13:07.7828 INFO Configuring fabrique to 192.168.100.4:8088.
2020-06-19 11:13:07.7828 INFO Configuring to 192.168.100.4:8088.
2020-06-19 11:13:18.7491 INFO Trying to send function <> in sync mode.
2020-06-19 11:13:18.7531 INFO Function URL is <http://192.168.100.4:8088/api?>.
2020-06-19 11:13:18.7531 INFO Creating vMix state form <vmix><version>23.0.0.57</version><edition>Pro</edition><inputs><input key="de3bf12a-4ea8-42ec-8401-2bc06af3c479" number="1" type="GT" title="Title 0- The Classic Blue.gtzip" shortTitle="Title 0- The Classic Blue.gtzip" state="Paused" position="0" duration="0" loop="False" selectedIndex="0">Title 0- The Classic Blue.gtzip<text index="0" name="Headline.Text">4-GT-NT-NOMBRES12:47:0000:00:20TrueTrueTrueTrueTrueTrueTrue1</text><text index="1" name="Description.Text">DESCRIPTION</text></input><input key="1154bb67-6b19-4273-9593-8cc6e194f45b" number="2" type="Blank" title="Blank" shortTitle="Blank" state="Paused" position="0" duration="0" loop="False">Blank</input></inputs><overlays><overlay number="1" /><overlay number="2" /><overlay number="3" /><overlay number="4" /><overlay number="5" /><overlay number="6" /></overlays><preview>2</preview><active>1</active><fadeToBlack>False</fadeToBlack><transitions><transition number="1" effect="Merge" duration="600" /><transition number="2" effect="Fade" duration="100" /><transition number="3" effect="Wipe" duration="1000" /><transition number="4" effect="CubeZoom" duration="1000" /></transitions><recording>False</recording><external>False</external><streaming>False</streaming><playList>False</playList><multiCorder>False</multiCorder><fullscreen>True</fullscreen><audio><master volume="100" muted="False" meterF1="0" meterF2="0" headphonesVolume="100" /><busA volume="100" muted="False" meterF1="0" meterF2="0" /><busB volume="100" muted="False" meterF1="0" meterF2="0" /></audio></vmix>.
2020-06-19 11:13:18.7531 INFO vMix state created.
2020-06-19 11:13:18.7531 INFO Configuring to 192.168.100.4:8088.
2020-06-19 11:13:18.7701 INFO Configuring to 192.168.100.4:8088.
2020-06-19 11:13:18.7701 INFO Widget "Excel Data" was copied.
2020-06-19 11:13:27.3191 INFO Checking vMix server.
2020-06-19 11:13:27.3290 INFO Checking vMix server.
2020-06-19 11:13:32.9522 ERROR Current domain unhandled exception. System.NullReferenceException: Referencia a objeto no establecida como instancia de un objeto.
en UTCExcelDataProvider.ExcelDataProvider.get_Values()
en vMixController.Widgets.vMixControlExternalData.<>c__DisplayClass45_0.<UpdateText>b__0(Object x)
en System.Threading.QueueUserWorkItemCallback.WaitCallback_Context(Object state)
en System.Threading.ExecutionContext.RunInternal(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx)
en System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx)
en System.Threading.QueueUserWorkItemCallback.System.Threading.IThreadPoolWorkItem.ExecuteWorkItem()
en System.Threading.ThreadPoolWorkQueue.Dispatch()
en System.Threading._ThreadPoolWaitCallback.PerformWaitCallback()
elgarf
#815 Posted : Saturday, June 20, 2020 3:00:20 AM(UTC)
elgarf
Russian Federation
@JAIRODJ, can you also share xls/xlsx in PM?
P.S. Looks like I don't tested it on more complex xlsx, than just table of numbers)
Download and replace data provider, I'll made an update later tomorrow if there are another bugs.
David Kaz
#816 Posted : Saturday, June 20, 2020 8:17:50 PM(UTC)
David Kaz
Russian Federation
I have tried to use Excel files maked in Open Office. All working good. Simple table with teams parameters.
elgarf
#817 Posted : Sunday, June 21, 2020 10:33:30 PM(UTC)
elgarf
Russian Federation
I've added T-Bar and undo by one step back (can be buggy) in this version.
Also I've changed a bit Timer widget design.
Universal Title Controller (updated 21.06.2020)
Changelog
21.06.2020:
+ T-Bar widget
+ One-Step-Back Undo
! Fixed Excel Data Provider bug
Chircanu on 6/21/2020(UTC)
Chircanu
#818 Posted : Monday, June 22, 2020 12:01:45 AM(UTC)
Chircanu
Changelog
21.06.2020:
+ T-Bar widget
Thanks for the update, I found two errors. NDI Monitor does not work, and when I undo the program stops. Thank you very much, a beautiful day everyone!
elgarf
#819 Posted : Monday, June 22, 2020 1:24:00 AM(UTC)
elgarf
Russian Federation
@Chircanu, oops. Now error in undo will be in log, and I fixed external datas.
Re-download, please. Link is the same.
Chircanu on 6/22/2020(UTC)
chococrispis35
#820 Posted : Saturday, June 27, 2020 2:21:16 AM(UTC)
chococrispis35
eLGARF
IN THE TEXT WIDGET IS THERE AN OPTION TO SELECT A GRAPHIC,
BECAUSE SOMETIMES YOU SELECT THE TEXT AND ACCIDENTALALLY SELECT THE GRAPHIC INPUT,
CAN YOU HAVE AN OPTION TO APPEAR OR NOT, ADD THIS FUNCTION IN PROPERTIES?
THIS WOULD SAVE UTC DISPLAY SPACE
tHANKS
Guest (26)
