JefHaugh
#1 Posted : Friday, June 19, 2020 8:02:54 AM(UTC)
JefHaugh
I would like the option to set my own password for the vMix call, even if it is still only numerals. I would also prefer that the password wouldn't reset every time I go to check the settings.
thanks 1 user thanked JefHaugh for this useful post.
Hylkewolf on 6/19/2020(UTC)
#2 Posted : Friday, June 19, 2020 4:08:17 PM(UTC)
Was thanked: 794 time(s) in 589 post(s)
All vMixCall passwords must be unique so that connections can be established correctly between users.
If vMix lets you choose your password, it is very likely that this password is already in use for somebody else and your callers are routed to the wrong place.
xaver
#3 Posted : Friday, June 19, 2020 4:50:49 PM(UTC)
xaver
save it as preset, so you can have always the same password
Hylkewolf
#4 Posted : Friday, June 19, 2020 8:18:04 PM(UTC)
Hylkewolf
Netherlands
I also would really like this option!
Now i always do send the link last-minute to the callers and test it last-minute.
elvis55
#5 Posted : Friday, June 19, 2020 8:24:50 PM(UTC)
elvis55
Switzerland
Was thanked: 55 time(s) in 49 post(s)
xaver
#6 Posted : Friday, June 19, 2020 8:27:18 PM(UTC)
xaver
it's discribed often in the forum
setup a call
save a preset
next time you can append only the "call" preset and have the same password again
that works very well
as DWAM writes, the PW is unique, so it's difficult to mae our own
Paul Camino
#7 Posted : Wednesday, July 8, 2020 2:25:20 PM(UTC)
Paul Camino
I would like a user defined password on top of the call provided password. (Or like a 4 digit pin)
I've run into situations where a call was reused and an old caller used the same password instead of a new one they were given, so it kicked the person that was on the old call. This way we can keep a current login, and just change out the pin for new shows.
epicenter800
#8 Posted : Thursday, July 9, 2020 8:19:52 AM(UTC)
epicenter800
+1
Paul Camino
#9 Posted : Thursday, October 8, 2020 2:32:53 AM(UTC)
Paul Camino
Bumping to group with other threads about this topic.
Guest (4)
Similar Topics
Vmix Call Passwords (vMix Call)
by carlofornasari 8/13/2020 4:49:57 PM(UTC)
vMix call Password/link missing (vMix Call)
by EV20 4/5/2020 12:38:54 AM(UTC)
Add Link Generator for Existing vMix Call Passwords (Feature Requests)
by sinc747 11/8/2017 5:21:54 PM(UTC)
