vmixusersrb
#1 Posted : Thursday, April 16, 2020 3:53:26 AM(UTC)
vmixusersrb
Serbia
It would be great to have option to take display capture of virtual desktop which is located in Task View (on the task bar in windows 10).
This option will provide as to use multiple capturing display even if we don't have external monitor on our desk.
Virtual desktop.png (27kb) downloaded 3 time(s).
monlao23
#2 Posted : Wednesday, June 17, 2020 7:06:49 PM(UTC)
monlao23
You have been a member since:: 6/17/2020(UTC)
Qatar
I am also reasearching how to do this. Do you have any update?
vmixusersrb
#3 Posted : Wednesday, June 17, 2020 7:35:43 PM(UTC)
vmixusersrb
Serbia
No one hit + for this request feature, so I think that they won't add this.
elvis55
#4 Posted : Wednesday, June 17, 2020 7:46:28 PM(UTC)
elvis55
Switzerland
Was thanked: 57 time(s) in 51 post(s)
Adding Local Desktops
Window Capture Method
Select the method used to capture individual Windows.
GDI: This will work on the vast majority of systems with the exception of Windows Store apps and browsers such as FireFox and Chrome.
WindowsGraphicsCapture: This is available on Windows 10 1809 or higher and captures most applications including browsers and Windows Store apps.
DWM: This is available on earlier versions of Windows 10 and Windows 7 and can capture the same windows as GDI but with slightly lower CPU/GPU resource usage.
