Feature Requests
Virtual Desktop Windows 10 Capture
Joined: 4/8/2020(UTC) Posts: 10  Location: Belgrade Was thanked: 1 time(s) in 1 post(s)
It would be great to have option to take display capture of virtual desktop which is located in Task View (on the task bar in windows 10). This option will provide as to use multiple capturing display even if we don't have external monitor on our desk.  Virtual desktop.png (27kb) downloaded 3 time(s).
I am also reasearching how to do this. Do you have any update?
No one hit + for this request feature, so I think that they won't add this.
Joined: 3/17/2017(UTC) Posts: 452  Location: Luzern - Schweiz Thanks: 69 times Was thanked: 57 time(s) in 51 post(s)
Adding Local DesktopsWindow Capture Method Select the method used to capture individual Windows. GDI: This will work on the vast majority of systems with the exception of Windows Store apps and browsers such as FireFox and Chrome. WindowsGraphicsCapture: This is available on Windows 10 1809 or higher and captures most applications including browsers and Windows Store apps. DWM: This is available on earlier versions of Windows 10 and Windows 7 and can capture the same windows as GDI but with slightly lower CPU/GPU resource usage.
Feature Requests
