kevev
#1 Posted: : Monday, June 15, 2020 11:02:19 AM(UTC)
kevev
Was thanked: 9 time(s) in 5 post(s)
I see there is a shortcut "ReplayShowHide".
Is there a shortcut "ReplayShow"?
Or is there a workaround for this?
I have users that get lost if they accidentally munimize the replay controls. :)
#2 Posted : Monday, June 15, 2020 5:22:15 PM(UTC)
As its name implies, this shortcut shows when it's hidden and hides when it's shown...
Testing it takes less time than asking the question btw...
doggy on 6/15/2020(UTC)
kevev
#3 Posted : Tuesday, June 16, 2020 2:23:46 AM(UTC)
kevev
I guess you didn't understand my question...
I am wondering if there is a shortcut that does only show replay controls.
#4 Posted : Tuesday, June 16, 2020 2:35:18 AM(UTC)
So you were asking if it was possible to see the replay controls back when a user accidentally hid these controls and DWAM gave a correct answer but now you are asking to ONLY show these controls ?
unpin them and/or drag them to another monitor , the same shortcut will apply (try it)
If one accidentally minimizes something then one is not paying attention
kevev
#5 Posted : Tuesday, June 16, 2020 3:13:59 AM(UTC)
kevev
This is my actual question, "Is there a shortcut "ReplayShow"?"
I cannot use the "ReplayShowHide" shortcut.
I need a shortcut that does ReplayShow.
#6 Posted : Tuesday, June 16, 2020 3:25:21 AM(UTC)
it does BOTH ! show when hidden , hides when shown !
otherwise if not in the list then no
kevev
#7 Posted : Tuesday, June 16, 2020 4:25:54 AM(UTC)
kevev
OK. Looking for another way to do this. Maybe a script?
#8 Posted : Tuesday, June 16, 2020 7:55:15 AM(UTC)
controlling vMix with a script is using the available shortcuts basically
kevev
#9 Posted : Tuesday, June 16, 2020 9:40:59 AM(UTC)
kevev
Understood. Thank You.
