Thanks: 6 times Was thanked: 9 time(s) in 5 post(s)
I see there is a shortcut "ReplayShowHide".
Is there a shortcut "ReplayShow"?
Or is there a workaround for this?
I have users that get lost if they accidentally munimize the replay controls. :)
As its name implies, this shortcut shows when it's hidden and hides when it's shown... Testing it takes less time than asking the question btw...
Originally Posted by: DWAM  As its name implies, this shortcut shows when it's hidden and hides when it's shown... Testing it takes less time than asking the question btw... I guess you didn't understand my question... I am wondering if there is a shortcut that does only show replay controls.
Joined: 12/27/2012(UTC) Posts: 5,523  Location: Belgium Thanks: 318 times Was thanked: 1021 time(s) in 838 post(s)
So you were asking if it was possible to see the replay controls back when a user accidentally hid these controls and DWAM gave a correct answer but now you are asking to ONLY show these controls ?
unpin them and/or drag them to another monitor , the same shortcut will apply (try it)
If one accidentally minimizes something then one is not paying attention
Originally Posted by: doggy  So you were asking if it was possible to see the replay controls back when a user accidentally hid these controls and DWAM gave a correct answer but now you are asking to ONLY show these controls ?
If one accidentally minimizes something then one is not paying attention This is my actual question, "Is there a shortcut "ReplayShow"?" I cannot use the "ReplayShowHide" shortcut. I need a shortcut that does ReplayShow.
it does BOTH ! show when hidden , hides when shown !
otherwise if not in the list then no
OK. Looking for another way to do this. Maybe a script?
controlling vMix with a script is using the available shortcuts basically
Originally Posted by: doggy  controlling vMix with a script is using the available shortcuts basically Understood. Thank You.
