Is there something changed between version 11.0.0.63 and 11.0.0.66 with the audiodelay My audio in the last version is now out of sync. I must change for every new Videofile the audiodelay with aprox 30mS Or is there another way to do so ??
greetings from the Netherlands Otto Schröder
Joined: 1/13/2010(UTC) Posts: 5,317  Location: Gold Coast, Australia Was thanked: 4719 time(s) in 1617 post(s)
Audio functionality has not changed in .66 Where do you notice the audio delay? Recordings, streaming, through the headphones?
Martin vMix
admin wrote:Hi,
Martin vMix Hello Martin, thanks for your quick reply ! I noticed it on the output on my Blackmagic Duo. The SDI output of this card is connected to the Blackmagic SDI -> HDMI converter, and the HDMI output is connected to my TV. Everything worked fine in 11.0.0.63, but now i have to delay the audio in every AddInput Video -> (Audio Settings) and set the delay to aprox 20-30 ms. any suggestions ? grt Otto
You can set the delay just on the External Output settings rather than for every input. However, make sure your external output audio settings are set correctly, it should be Decklink Audio Render for audio device and vMix Audio for input audio device.
Martin vMix
admin wrote:Hi,
Martin vMix Hi Martin, I did what you suggested, and as a result i have an echo in the audio. Then i opened a preset that i saved earlier with version 11.0.0.63, and there was again a delay in the audio. I'm'realy confused what happened .... gr Otto
Could you please post a screenshot of your External Output settings?
Thanks,
Martin vMix
Actually, something else to check is to make sure in windows the audio is not set to go to Decklink. Check under Control Panel -> Hardware and Sound -> Sound and make sure playback is not set to Decklink.
Also make sure only Default Directsound Device is selected in vMix Settings under the Audio tab.
admin wrote:Could you please post a screenshot of your External Output settings?
Thanks,
Martin vMix I tried to upload a picture of my settings, but it failed to do so...
admin wrote:Actually, something else to check is to make sure in windows the audio is not set to go to Decklink. Check under Control Panel -> Hardware and Sound -> Sound and make sure playback is not set to Decklink.
I did all that, but still, the delay is noticeable ... gr Otto
As mentioned Input Audio Device needs to be vMix Audio, Audio Device needs to be Decklink Audio Render.
Then in Windows go to Control Panel -> Hardware and Sound -> Sound and make sure the output audio is NOT set to blackmagic. Then go to vMix Settings -> Audio and make sure the output device there is set to Default DirectSound Device.
Martin vMix
admin wrote:As mentioned Input Audio Device needs to be vMix Audio, Audio Device needs to be Decklink Audio Render.
Martin vMix Hi Martin, Looks like ok now...I wonder why it worked before in v. 11.0.0.63.... But..don't look back...its working now !! I'm very happy with VMIX.. gr. from Holland Otto
