otto
#1 Posted : Tuesday, January 14, 2014 12:02:51 PM(UTC)
otto
Is there something changed between version 11.0.0.63 and 11.0.0.66 with the audiodelay
My audio in the last version is now out of sync.
I must change for every new Videofile the audiodelay with aprox 30mS
Or is there another way to do so ??
greetings from the Netherlands
Otto Schröder
#2 Posted : Tuesday, January 14, 2014 10:03:30 PM(UTC)
Audio functionality has not changed in .66
Where do you notice the audio delay? Recordings, streaming, through the headphones?
otto
#3 Posted : Wednesday, January 15, 2014 12:02:24 PM(UTC)
otto
Hello Martin,
thanks for your quick reply !
I noticed it on the output on my Blackmagic Duo.
The SDI output of this card is connected to the Blackmagic SDI -> HDMI converter,
and the HDMI output is connected to my TV.
Everything worked fine in 11.0.0.63, but now i have to delay the audio in every AddInput Video -> (Audio Settings)
and set the delay to aprox 20-30 ms.
any suggestions ?
grt
Otto
#4 Posted : Wednesday, January 15, 2014 9:54:19 PM(UTC)
You can set the delay just on the External Output settings rather than for every input.
However, make sure your external output audio settings are set correctly, it should be Decklink Audio Render
for audio device and vMix Audio for input audio device.
otto
#5 Posted : Thursday, January 16, 2014 12:43:26 PM(UTC)
otto
Hi Martin,
I did what you suggested, and as a result i have an echo in the audio.
Then i opened a preset that i saved earlier with version 11.0.0.63,
and there was again a delay in the audio.
I'm'realy confused what happened ....
gr
Otto
#6 Posted : Thursday, January 16, 2014 9:49:51 PM(UTC)
Could you please post a screenshot of your External Output settings?
Thanks,
#7 Posted : Thursday, January 16, 2014 9:51:31 PM(UTC)
Actually, something else to check is to make sure in windows the audio is not set to go to Decklink.
Check under Control Panel -> Hardware and Sound -> Sound and make sure playback is not set to Decklink.
Also make sure only Default Directsound Device is selected in vMix Settings under the Audio tab.
otto
#8 Posted : Friday, January 17, 2014 4:37:21 PM(UTC)
otto
Thanks,
I tried to upload a picture of my settings, but it failed to do so...
otto
#9 Posted : Friday, January 17, 2014 4:38:40 PM(UTC)
otto
I did all that, but still, the delay is noticeable ...
gr
Otto
#10 Posted : Friday, January 17, 2014 9:45:40 PM(UTC)
You can upload a screenshot using https://fileobject.com/
otto
#11 Posted : Saturday, January 18, 2014 2:31:21 PM(UTC)
otto
Screenshot of my External Output Settings
https://fileobject.com/lqypyvvajyltva/
gr
Otto
#12 Posted : Saturday, January 18, 2014 9:43:34 PM(UTC)
As mentioned Input Audio Device needs to be vMix Audio, Audio Device needs to be Decklink Audio Render.
Then in Windows go to Control Panel -> Hardware and Sound -> Sound and make sure the output audio is NOT set to blackmagic.
Then go to vMix Settings -> Audio and make sure the output device there is set to Default DirectSound Device.
otto
#13 Posted : Sunday, January 19, 2014 6:54:58 AM(UTC)
otto
Hi Martin,
Looks like ok now...I wonder why it worked before in v. 11.0.0.63....
But..don't look back...its working now !!
I'm very happy with VMIX..
gr. from Holland
Otto
