NDI
Deinterlace NDI input
Hello, I am trying to remove interlace artefacts when using an interlaced NDI input, i am outputting an SRT stream with H264 video. I am recieving an NDI stream from Avid media composer, sometimes Vmix sees the stream as 25p and sometimes as 50i. I have tried turning on de-interlacing in the input settings, and it is also enabled in output settings but even when the input is seen as interlaced I am still seeing combing artefacts on the SRT stream. I'm running the latest version of Vmix. Any advice appreciated! Thanks.  NDI input.JPG (52kb) downloaded 3 time(s). OUtput.JPG (58kb) downloaded 0 time(s).
If you're still having a problem, you might like to try and compare the de-interlacing options in my free ZEN RTx NDI Receiver/Transmitter which can be externally "inserted" into the incoming NDI signal path. It has interpolated and blended field deinterlacing options for interlaced inputs.  NDI_RTx10917DeInt.png (71kb) downloaded 9 time(s).
NDI
