2 Pages<12
lestra
#21 Posted : Saturday, June 13, 2020 3:37:04 AM(UTC)
lestra
Saint Kitts And Nevis
Originally Posted by: DWAM Go to Quoted Post
But how to stream out SRT from VLC at the same time?
2 VLC instances, one to stream out, one to receive return feed.
I'd do it with FFMPEG (which is btw what VLC, OBS and many other SRT compliant softwares use in the background). There are many examples on how to do it on the internet.
The OBS solution works OK too but will be difficult to handle audio for the out and the return at the same time
Another solution is to stream SRT out from a smartphone with Larix...
... and get the return feed on the laptop with FFMPEG (Zeranoe builds support SRT from over 1 year at least) which is as easy as typing this at the command line shell (can be provided as a script btw)
ffplay -i srt://0.0.0.0:PORT/?mode=listener
Last but not least, vMix, either the free trial or the BasicHD version, will do it too
Thank You Dwam. I will try some of your sugestions. Is it possible to make bat file for easy start stream from guest side (ffmpeg option)?
#22 Posted : Saturday, June 13, 2020 5:02:01 AM(UTC)
Sure ! Create a txt file on your desktop, rename it to srt-player.cmd and just copy this two lines in it. More options are available if needed, check ffplay documentation and adapt for the correct path to ffplay executable and your port choice obviously
@echo off
c:\\dwam\ffmpeg\bin\ffplay -stats -i srt://0.0.0.0:15000/?mode=listener
eduardocfs on 6/13/2020(UTC)
lestra
#23 Posted : Saturday, June 13, 2020 3:17:52 PM(UTC)
lestra
I will try that, thanks DWAM!
ggudnason
#24 Posted : Saturday, June 13, 2020 6:52:25 PM(UTC)
ggudnason
Was thanked: 8 time(s) in 7 post(s)
As already mentioned you can do this with OBS. The best way I have found is to have all sources and audio inside the scene. So you have to make sure that obs is not picking up any desktop audio and only sending the mic audio. To get the return feed you add a media source that gets the srt feed. into the same scene and make sure it is below the camera you are using so that it will not show on stream. Then in advanced audio properties you make sure that you are monitoring the audio only from the return feed. To be able to see it as it under the webcam right click on the media source and use as a projector source. windowed or fullscreen as you prefer.
sending and receiving the srt within obs you can find instructions online.
lestra
#25 Posted : Saturday, June 13, 2020 7:00:11 PM(UTC)
lestra
I am looking for "One Click" solution for non tech users on the guest side on the laptop. So far there are two solutions, (not yet "one click"):
1. https://garaninapps.com/srt
2. OBS
I will try to make portable version of OBS with all settings done...
2 Pages<12
