jet
#1 Posted : Tuesday, June 9, 2020 7:50:21 PM(UTC)
jet
Was thanked: 24 time(s) in 22 post(s)
Hi.
Is there a way to change Input source by a shortcut?
So say one would like to change source file of PowerPoint presentantion on Input #10 with Shotcut, or relplace the entire input with an entire different input type, like camera input?
For now it would be enough for me to get opened the "Select input" -window with a shotcut.
Kind regards,
Jan
#2 Posted : Tuesday, June 9, 2020 8:02:30 PM(UTC)
Check the shortcut list. There is one to add an input and to place it at a specific input number
jet
#3 Posted : Tuesday, June 9, 2020 8:12:36 PM(UTC)
jet
Hi!
Yes, I did check the shortcut list and I did not find a suitable function for this changing/replacing purpose.
Kind regards,
Jan
#4 Posted : Tuesday, June 9, 2020 8:16:42 PM(UTC)
Alternatively you can also make input #10 a "blank input" and use "SetMultiViewOverlay" command to send any of your inputs as an overlay in input #10. This way your input #10 shortcuts are always available whichever inputs it really shows...
#5 Posted : Tuesday, June 9, 2020 8:17:46 PM(UTC)
You did not search well then...
#6 Posted : Tuesday, June 9, 2020 8:22:03 PM(UTC)
"Hover" command is another solution for your usecase
