How to trigger Change Source
Joined: 11/14/2012(UTC) Posts: 388  Location: Finland Thanks: 247 times Was thanked: 31 time(s) in 29 post(s)
Hi.
Is there a way to change Input source by a shortcut?
So say one would like to change source file of PowerPoint presentantion on Input #10 with Shotcut, or relplace the entire input with an entire different input type, like camera input?
For now it would be enough for me to get opened the "Select input" -window with a shotcut.
Kind regards, Jan
Joined: 12/27/2012(UTC) Posts: 5,534  Location: Belgium Thanks: 318 times Was thanked: 1021 time(s) in 838 post(s)
Check the shortcut list. There is one to add an input and to place it at a specific input number
Hi!
Yes, I did check the shortcut list and I did not find a suitable function for this changing/replacing purpose.
Kind regards, Jan
Alternatively you can also make input #10 a "blank input" and use "SetMultiViewOverlay" command to send any of your inputs as an overlay in input #10. This way your input #10 shortcuts are always available whichever inputs it really shows...
Quote:Yes, I did check the shortcut list and I did not find a suitable function for this changing/replacing purpose. You did not search well then...
"Hover" command is another solution for your usecase
