dropped Frames with Decklink Duo2 and vMix 23.0.0.57
Joined: 4/12/2020(UTC) Posts: 17  Was thanked: 1 time(s) in 1 post(s)
does anybody also have many dropped Frames in the external Renderer with Decklink Cards and the latest vMix version 23.0.0.57 ? About hundrets of dropped Frames in an hour.
Did an downgrade to .54 and in over 16h of External just about 10 dropped Frames.
Decklink Driver are the latests.
A college also have this problem with one of his Systems, and that one is on .57
Markus
Hi we also use some Decklink Duo2 (720p50) on 23.0.0.57 tested now one hour at 2 Inputs 8 dropped frames 3. Input 10 dropped frames
only the inputs with no signal have a lot of dropped frames (but I thinks thats normal)
Joined: 1/13/2010(UTC) Posts: 5,316  Location: Gold Coast, Australia Was thanked: 4718 time(s) in 1616 post(s)
There is no change to these inputs at all in the latest vMix update, so any drops in frames will depend on the resource usage in vMix at the time and not something to do with the updates, so check your settings to see what might be different between the two.
Martin vMix
Thanks Martin,
i´m already doing further tests.
Markus
