newmans
#1 Posted : Monday, June 8, 2020 4:54:27 AM(UTC)
newmans
Germany
does anybody also have many dropped Frames in the external Renderer with Decklink Cards and the latest vMix version 23.0.0.57 ?
About hundrets of dropped Frames in an hour.
Did an downgrade to .54 and in over 16h of External just about 10 dropped Frames.
Decklink Driver are the latests.
A college also have this problem with one of his Systems, and that one is on .57
Markus
xaver
#2 Posted : Monday, June 8, 2020 5:37:59 PM(UTC)
xaver
Hi
we also use some Decklink Duo2 (720p50) on 23.0.0.57
tested now one hour
at 2 Inputs 8 dropped frames
3. Input 10 dropped frames
only the inputs with no signal have a lot of dropped frames (but I thinks thats normal)
#3 Posted : Tuesday, June 9, 2020 3:10:31 AM(UTC)
There is no change to these inputs at all in the latest vMix update, so any drops in frames
will depend on the resource usage in vMix at the time and not something to do with the updates, so check
your settings to see what might be different between the two.
newmans
#4 Posted : Wednesday, June 10, 2020 4:43:42 AM(UTC)
newmans
Germany
Thanks Martin,
i´m already doing further tests.
Markus
