davidc
#1 Posted : 5 years ago
davidc
The idea behind this is that I want to have some shortcuts to turn overlays off, but only one shortcut per overlay. Whilst this is possible, it is not possible to tell my midi controller to light up a button if, for example, overlay 1 is in use, this is because you have to select an input when you select "Overlay1" as the event.
#2 Posted : 5 years ago
Was thanked: 989 time(s) in 821 post(s)
davidc
#3 Posted : 5 years ago
davidc
Thanks, but I’ve seen that video and it doesn’t stop me needing this feature.
Either that or there is a bug as if you select “Active” in the input dropdown, it doesn’t work if overlay1 is active. It only work if the overlay input is in the program output and being used as an overlay at the same time (which no one in their right mind would ever want to do!)
#4 Posted : 5 years ago
hmm
what does work if you put an input in the preview first and then overlay that input the light does show up (workaround)
Shortcut put input in preview AND overlay nr, specify preview for the activator
advisiontv
#5 Posted : 5 years ago
advisiontv
Yes - you would think this could be possible as you have the ability to turn the overlay off with the buttons between Preview and Program. They just need to be replicated by hardware.
I would love the ability to be able to assign a whole row of key inputs to my hardware mixer and also have 4 overlay assign buttons. Simply toggling between these 4 would highlight which input is assigned. I believe the only current way of doing this is to have four individual rows - one for each overlay. Another 4 Direct Key buttons could then simply key on and off the overlay.
davidc
#6 Posted : 5 years ago
davidc
Originally Posted by: doggy Go to Quoted Post
hmm
Not quite a workaround for me as I’ll need the preview for other things widest the overlay is being used, so I can’t set the activator to use the preview. If this wasn’t the case it would be an acceptable workaround.
#7 Posted : 5 years ago
Was thanked: 794 time(s) in 589 post(s)
Before posting new Features Requests, it is advised to check if similar FR do not already exist... and add your +1 as the case may be. FR are considered when they are popular, the more similar FR, the less imapct they have.
https://forums.vmix.com/...n-multiview-or-External2
