Martin van der Reijden
#1 Posted : Sunday, June 7, 2020 9:43:11 PM(UTC)
Netherlands
How can I transfer texts made in a lower third to another lower third?
#2 Posted : Sunday, June 7, 2020 10:49:40 PM(UTC)
how is the text in that lower third made/placed in the first place ? part/embedded of/in the title (graphic) design , put in manually with the title editor , or through a data source or .... ?
That all would give a different answer
#3 Posted : Sunday, June 7, 2020 10:50:11 PM(UTC)
in title editor, use export as csv
in the other title, import csv
https://www.vmix.com/help23/Title.html
mavik
#4 Posted : Monday, July 6, 2020 4:39:58 AM(UTC)
mavik
If you use a txt or csv you can add them as a datasource for both. One file for two or more titles via datasource.
