Jp12687
#1 Posted : Saturday, June 6, 2020 12:27:22 PM(UTC)
Jp12687
Hi
Trying to do some research to see if we have a multi audio track NDI feed will each audio feed show up in vmix?
Is there a better way to select the correct audio channel we want to hear?
This way we could have multiple different channels and people watching and hearing a different version
zenvideo
#2 Posted : Sunday, June 7, 2020 3:10:46 AM(UTC)
zenvideo
Yes, vMix accepts multi-channel NDI audio - albeit within a single input, which means you only get to control the relative levels of the various channels via the Channel Mixer tab of the audio settings for that NDI input.
Showing the Audio Channel Mixer with multiple NDI input channels
However, you are able to assign where the individual input channels are sent, via the Channel Matrix tab, so it's possible to have Ch1-2 to Bus A, Ch3-4 to Bus B, Ch5-6 to Bus C, etc.
Showing the Audio Channel Matrix with multiple NDI input channels
Jp12687
#3 Posted : Sunday, June 7, 2020 3:26:12 AM(UTC)
Jp12687
Awesome-- so if I had a single NDI feed that had different channels with English, German, & Spanish translation and I view the NDI input I could then use the mixer to select which one of those channels I'd want to hear and "mute" the rest depending on who is watching?
zenvideo
#4 Posted : Sunday, June 7, 2020 4:08:35 AM(UTC)
zenvideo
Correct.
