NDI
Multi Audio Channel NDI selector
Hi
Trying to do some research to see if we have a multi audio track NDI feed will each audio feed show up in vmix?
Is there a better way to select the correct audio channel we want to hear?
This way we could have multiple different channels and people watching and hearing a different version
Joined: 5/13/2014(UTC) Posts: 521   Location: Manchester, UK Thanks: 2 times Was thanked: 183 time(s) in 130 post(s)
Originally Posted by: Jp12687  Trying to do some research to see if we have a multi audio track NDI feed will each audio feed show up in vmix?
This way we could have multiple different channels and people watching and hearing a different version Yes, vMix accepts multi-channel NDI audio - albeit within a single input, which means you only get to control the relative levels of the various channels via the Channel Mixer tab of the audio settings for that NDI input.  However, you are able to assign where the individual input channels are sent, via the Channel Matrix tab, so it's possible to have Ch1-2 to Bus A, Ch3-4 to Bus B, Ch5-6 to Bus C, etc.
Awesome-- so if I had a single NDI feed that had different channels with English, German, & Spanish translation and I view the NDI input I could then use the mixer to select which one of those channels I'd want to hear and "mute" the rest depending on who is watching?
NDI
